04-21-2022, 01:38 AM | #1 |
Rep 21
Change of brake callipers
Just had the standard brakes changed to the 370/330mm set up and noticed the first press of the brake pedal when braking has a lot of travel and does not feel as though it is biting hard. When pressed again straight afterwards it is hard and has good bite.
Is this because they need coding with e-sys or a result of a poor bleed procedure. I read the brakes can feel mushy without coding. It is only the first use of the brakes each time I brake. Is this the typical symptom? |
04-21-2022, 02:43 AM | #2 | |
Rep 55
05-02-2022, 06:04 PM | #3 | |
Rep 104
Drives: BMW 328i
Thinking about doing the swap myself but i dont want to do the coding. |
