BMS Oil Catch Can Vacuum Side
04-23-2022, 04:01 PM | #1 |
Rep 169
Is this normal for the oil to looks like this on the vacuum side of the BMS OCC? Oil inside of the engine is fine, I just changed the oil
04-25-2022, 06:39 AM | #2 |
Rep 99
From what I know, ( not a lot ). You either have a blown head gasket, your oil filter housing gasket is bad, or you don't let your car get up to full driving temperature when driving and you shut it off early, ( like if you work 5 minutes from home ).
lightmanek116.50 |
04-25-2022, 10:58 AM | #4 |
Rep 1,165
Drives: 09 E92 335i 6MT
+1. Drive the car longer, and as it gets warmer out it will be less like this. Completely normal. In colder months I keep a glove on my can, may do nothing but I don't care.
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
05-07-2022, 11:12 AM | #6 |
Rep 169
05-07-2022, 12:56 PM | #7 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Do you have a vtt crank case breather by chance?
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
05-10-2022, 01:00 PM | #10 |
Rep 1,165
You probably don't take trips less than 20 minutes often, do you?
05-10-2022, 02:45 PM | #11 |
Rep 4,203
I don't either really though, cold weather half the year.. I can't figure it out yet. Seeping through valve cover building up condensation
E93Dude369.00 |
05-14-2022, 01:47 PM | #12 |
Rep 4,203
What pcv are you running with the BMS low side catch can?
