04-24-2022, 06:44 PM | #2 |
Rep 1,084
Measure how much higher you want to go, remove springs, adjust then replace. I don't think anyone has been able to adjust while on the car with that tool. Too much tension and access is tight.
04-24-2022, 07:03 PM | #3 | |
Rep 343
Just make sure you blow off all the dust to make the adjuster turning easier. The provided adjusting tool is a must. |
04-24-2022, 07:31 PM | #4 |
Rep 284
I understand that it’s a little hard to do with on the car but do I close the gap or go further away from the bottom perch I know on the front the lower you turn the perch the lower the car goes but on the back it’s if you turn it down to close the Perch does the car sit higher
04-24-2022, 11:11 PM | #5 | |
Rep 1,084
04-24-2022, 11:13 PM | #6 | |
Rep 1,084
04-25-2022, 09:29 AM | #8 |
BimmerPost Supporting Vendor
24348
Rep 191,145
04-26-2022, 08:31 AM | #9 | ||
Rep 1,416
