05-01-2022, 12:05 PM | #1 |
Rep 1,372
Lowering vs Front Splitter
If I lower my car with the M-Sport bumper on my F30 wouldn’t that be the same as adding a front splitter? Lowering would also close the side skirt-pavement gap as well.
Interested in getting some feedback on this topic
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
05-01-2022, 01:00 PM | #2 |
Rep 4,380
imo, lowering is lowering.
adding a front splitter is just lowering the chin of the bumper and altering/enhancing aero with designed material(pu or cf). obviously a front splitter will not reduce the wheel gaps but may cause it to appear lowered if viewed from the front. not sure, if this is answers your question... |
cfm56d7b5948.50 |
05-01-2022, 03:09 PM | #3 | |
Rep 1,372
BMW mentions that if one adds a front splitter, one should also add a rear trunk spoiler as well. If lowering car has the same effect as adding a splitter (i.e. limiting air flow getting under the car), would it mean lowering also means one should add rear trunk spoiler?
05-01-2022, 04:05 PM | #4 |
Rep 4,380
ahh, okay. this is beyond my knowledge of car aerodynamics. but my limited speculation is, the splitter increases the cross section and redirects airflow around the car, so it's actually causing a higher pressure area below the vehicle, which would actually cause lift, so maybe the spoiler is to reduces lift created by the splitter?
if you look at a formula1 car it is actually shaped like an upside down wing so the higher pressure air is above it pushing down, as well as the front and rear wings(also upside down) idk, this is beyond me, so it's prolly best we wait for an SME in vehicle aerodynamics to chime in i feel the splitter affects the aero more than lowering but i really don't know. whatever the case, you'd have to be driving quite fast to realize it's affect. most of us on the forum are just doing it for appearance |
05-01-2022, 04:24 PM | #5 |
Rep 895
The M Perf front splitter (like on my 435) is actually a downforce enhancing design. It’s not an air dam. The wide lower ‘edge’ is actually a beefy inverted wing (flat on top, airfoil on the bottom), generating downforce. At speed it lowers the car chassis from this aero design flowing air thru/past the wing above and below. They advise a paired aerodynamically-matched rear spoiler so the rear downforce balances the car from going nose down at speed.
It’s not = statically lowering the car |
05-01-2022, 04:29 PM | #6 | |
Rep 2,055
With a splitter air still gets underneath but the less airflow getting underneath the car the better as it pushes the displaced air over rather than under, creating high pressure above the car and low pressure beneath, i.e downforce. Big motorsport splitters do this very effectively, road going ones less so as they're too far from the ground because they need to clear obstacles (look at the rally cars and they use flexible grp things to do that purpose). I suspect the aero balance may move slightly forwards with a splitter on the M bumper but I can't imagine it would be by enough to warrant an extra rear wing given the overall amount of downforce we're talking about (most stuff on a road car is minimising lift rather than creating downforce per a race car that's close to the ground). I mean look at the large STI rear wings on the Impreza, they offer zero downforce unless it's one of the adjustable top plane ones, and 99.9% of the ones you see aren't. |
05-04-2022, 09:27 AM | #7 |
Rep 55
In my opinion a front splitter is pretty much only a cosmetic upgrade for 99% of people, myself included. That isn't to say it's bad of course, make your car look how you like.
If you want to close the wheel gaps and the side skirt to pavement gap, you need to lower the car via suspension. You can add a splitter and it'll look lower in the front, but not at the sides of course. You can add skirts to close the pavement gap, but you'll still have wheel gaps. So, a front splitter is not the same as lowering, really not even close. |
Jvac438.00 |
05-04-2022, 02:45 PM | #8 |
Rep 10,322
Are you looking to enhance the visual appearance or improve aerodynamics?
05-06-2022, 10:43 AM | #9 | |
Rep 1,372
As much as I like the idea of adding a splitter to further help reduce under-car drag, plus add cosmetic flair, with the car being lowered, a splitter may end up in the sh*tter crashing into curbs or or any moderate incline, including driveways and maintenance ramps.
05-06-2022, 11:46 AM | #10 | ||
Rep 7,634
Curious why are you saying that the "amount of air" under the car is going to affect drag? The only thing that matters is the air you are disturbing. There can be a whole bunch of air under the car or only a little bit, the only thing that is going to affect drag is how much of that air the car is interacting with. If the majority of the air goes under the car undisturbed (or rather, the car "cuts" through the air without disturbing it since the car is what is moving), then you will have minimal drag. |
05-06-2022, 01:00 PM | #11 | |
Great Teacher
1139
Rep 1,320
Drives: 06 e91 325ix
Save fuel,not likely. Splitters aren’t airdams and airflow is already well controlled. Hell I LOST fuel economy after lowering from increased drag in the output shafts. But not anymore than I lost from adding performance tires with higher rolling resistance. Choose the right splitter and don’t drive into parking blocks or like a tool and you won’t have to worry about breaking it. See my car for an example. Edit. I know where your theory comes from, and it is applicable to prior cars, but these are flat bottomed skirted cars with nothing hanging out in the breeze, so you aren’t reducing drag by sending more air around the car vs under it.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
05-06-2022, 05:12 PM | #12 | ||
Rep 10,322
I would add that worrying about navigating on / off parking ramps may not be worth the trouble. |
05-06-2022, 06:15 PM | #13 | |
Rep 895
Many seem to confuse air dams (think vertical surfaces), spoilers (think slanted) and splitters (think horizontal). And these with ground effects, also different… |
cfm56d7b5948.50 |
05-06-2022, 06:17 PM | #14 |
Rep 7,634
FYI, i have stock ride height on 335i Msport RWD and my Msport front splitter unavoidably drags on any driveway/incline with even a moderate angle. I would consider it a consumable item and plan on replacing about every 5-10k miles. Mine is a ABS replica and it has worn through on the center. And yes, i know how to drive a low car, take driveways at an angle, etc. It's just low and overhangs even at stock height.
05-06-2022, 06:46 PM | #15 |
Rep 895
I hear ya - though I’m well into 2 years with mine, with only some minor scrapes in the center-front so far. (knock on cf)
My 435iX THP is also stock ride-height and I’ve measured the low point on the splitter (which is about 5” back and 1.25” lower than the leading edge) to be only 4.5” off the ground (static). That plus the extension in front of the normal bodywork = be careful out there. |
