05-09-2022, 08:53 PM | #1 |
Rep 68
Required Mods for Stage 1 E30?
I’m currently on Stage 1 Bootmod3 on ACN 91. I know that it’s ok to have no supporting mods for stage 1 on pump, but is the E30 safe to use long term without any other mods? I’ve never really done an ethanol mixture tune before, but I’ve always seen people needing like different fueling kits or pumps and what not.
So just curious of the BM3 E30 tune is generally ok to use without anything. Thanks |
07-23-2022, 09:59 PM | #4 |
Rep 803
True, the tune itself is safe with the OEM catalytic converter, however Ethanol is not good for it long term. So for the sake of the catalytic converter, I would not run the E30 stage 1 long term unless I had a catless DP.
07-24-2022, 07:46 AM | #6 |
Rep 372
Ethanol sensor would be good to have. E30 is fine. No one knows true long term results.
2022 BMW X3M - 11.604 @117.96
Gone But not forgotten 2008 BMW 135 - 10.9 @ 131 2016 BMW X6 |
07-25-2022, 06:03 AM | #7 |
Rep 95
07-25-2022, 10:38 AM | #8 | |
Rep 24
07-25-2022, 11:11 AM | #9 |
Rep 533
07-25-2022, 01:01 PM | #10 | |
Rep 24
So unless I've missed something, the fuelling is there for up to e60. Paul's own team even mention that anything above you have to reduce the boost level. |
07-25-2022, 01:52 PM | #11 | |
Rep 533
I'm happy you're not seeing any trouble on your map settings, but like I said earlier, I wouldn't be at all surprised if you run into some issues sooner than later. These factory lpfp's can't keep up with the required fueling on higher ethanol content in the long run. If you look at your fuel trims, I'll bet you're fully maxed on on your logs... unless you're not running your rig hard. I race, and do a lot of high rpm high speed runs for fairly long durations, so it's extremely taxing on the fueling system to supply that max effort fuel delivery for sustained time intervals. A few people have said I have a bad tuner who can't tune for my usage... Not the case. It's literally a weak lpfp not allowing the fueling needed for these higher fuel delivery requirements. |
07-25-2022, 02:07 PM | #12 | ||
Rep 24
On my last logs from 3rd to 5th the lpfp was in the 70s to 80s. Ill definitely be keeping the eye out, so appreciate the heads up. I hadn't read about many issues on this topic and haven't seen anyone mention having this issue on a Paul Johnson tune. Will keep an eye out in the coming weeks / months. |
10SecGG510.00 |
07-25-2022, 02:36 PM | #13 |
Rep 686
Drives: Your mom crazy
Garage List 2020 BMW M340i CURRENT [10.00]
2003 BMW 330i RIP [10.00] 2011 BMW 335i SOLD [10.00] 2016 BMW 340i SOLD [10.00] 2020 BMW X3M RIP [10.00] |
+1 for fueling issues at higher E%.
I ended up replacing both of my HPFPs due to issues at E50 custom tune. Replaced them and had my tuner walk it back to E40 and she's been much happier. I think the LPFP wasn't supplying enough fuel and ended up damaging the HPFPs. |
10SecGG510.00 The1EyedPigF9780.50 |
07-25-2022, 03:53 PM | #14 | |
Rep 95
Its not failing just reaches its limit. I am above 750whp on the E50 tune. Peaked out around 775whp and 1043wnm on the dyno. As soon as the fuel system gets hot it really starts struggling. its been dialed back and i am daily driving on E30. Managed to push E30 to 701whp 992wnm. I have eventuri filters, catless downpipes, mid pipe. so it can breathe. will see how lp pump upgrade fixes it before the port injection and E85-E100 tune happens. |
07-25-2022, 04:03 PM | #15 | |
Rep 1,000
FSociety3816.50 |
07-25-2022, 05:15 PM | #16 | ||
Rep 24
07-27-2022, 11:46 PM | #18 | |
IG @bmwF9xG80
3817
Rep 7,595
Drives: G80 M3, X4M, G07 X7m50
I've ran E30-E50 for my first 8,000 miles on stock hardware no issues on BM3 too. The particular guys having issues are using MHD (that guy who had to replace his HPFP for example).
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
07-28-2022, 08:16 AM | #19 | |
Rep 95
I cant see in MHd app what the lpfp is actually doing |
07-28-2022, 06:08 PM | #20 | |
IG @bmwF9xG80
3817
Rep 7,595
And LPFP is definitely not running out of fuel on Stock Turbos yet, look at the below Stock Turbo Stock Fueling *Records* BM3 still holds the following records for S58 Platform X3M/X4M (OP incase you interested to know) ** Stock Fueling No PI just Proper Custom Tuned on BM3 Platform ** - Stock Hardware 2020 X3M BrockDM 1/4 10.41s 60-130 7.11s - Stock Hardware LCI X3M jairomvp182 60-130mph 7.11s - 2020 X4M w/ DPs only 60-130mph 6.86s (myself) I know anyone who adds Port Injection should go faster but there's maybe only like 2 guys barely faster than Stock Turbos Stock Fueling since they're tuned outside of BM3
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 Last edited by FSociety; 07-28-2022 at 06:14 PM.. |
BrockDM2051.50 |
07-29-2022, 09:44 AM | #21 | |
Rep 533
07-29-2022, 10:24 AM | #22 | ||
Rep 1,000
