06-08-2022, 03:18 PM | #1 |
![]() ![]() 6055
Rep 5,450
Tire pressure - why my tires look so flat?
I see that these racing people with high volume tires set tire pressures at 21, 24 something like that
I have 255/35/19 RFTs and i am to set it at 39-50 COLD! I tried 35PSI and the tire looks so flat Even at 39 it still looks flat What gives? M340i is about 4000lbs with me in it |
06-08-2022, 03:19 PM | #2 |
![]() ![]() 6055
Rep 5,450
second question - maybe i need higher volume tires?
255 40 18 is exactly yhe same size i am after performance first second comfort looks not important any advice? |
06-08-2022, 04:00 PM | #3 |
![]() ![]() ![]() 11780
Rep 7,261
Drives: 2018 M2 AW DCT
If you are performance first, get rid of those run flats. Try Michelin PS4Ss in stock size. I run at stock pressure and tires look fine.
Westside Guy8010.50 DrFerry7808.00 |
06-08-2022, 04:12 PM | #4 | |
![]() ![]() 8011
Rep 5,575
That being said I will probably get the Pilot Sport 4s tires when it is time to replace my SS ones as the 4s is a fabulous dry and wet performer and perfect for where I live in South Florida. |
DrFerry7808.00 |
06-08-2022, 04:26 PM | #5 | |
![]() ![]() ![]() 6570
Rep 15,857
Smaller diameter rims give higher sidewalls and performance gives way to more comfort. That's what you'd be doing with a higher aspect ratio on your current rims. |
DrFerry7808.00 |
06-08-2022, 04:34 PM | #6 |
![]() ![]() ![]() 564
Rep 464
Pics?
I ran a (non-performance all season) tire at too low pressure during an autox a long time ago and think I destroyed the sidewalls inner construction. After that no matter the pressure, the sidewalls sagged out a bit and they looked flat. |
06-08-2022, 07:11 PM | #7 |
![]() ![]() 6055
Rep 5,450
the issue is that performance track cars run high(er) volume tires [eg 265 35 18] and low pressures [24 psi] - but hey it was a stripped out F series M4 ... so perhaps very light
when i look at mine it's low volume and high pressure! maybe a storm in a teacup ... 255 35 19 is probably same volume as 265 35 18 if not more ... will do some more reading .... yes that's why i'm asking questions, will be ditching RFTs on my next set |
06-09-2022, 04:19 AM | #8 | |
Rep 15,857
You'd also need to know rim widths for those sizes, that also has an influence, besides the pressure. I'd say the key thing to consider is, a stripped out track/racing coupe is far different for weight and chassis balance than a road going, load carrying wagon. ![]() |
06-09-2022, 07:48 PM | #9 |
![]() ![]() 6055
Rep 5,450
hmm my car recommends (255 35 19) 39 psi min
whereas the G80 recommends 32 psi min for the same tire https://www.carsguide.com.au/bmw/m-m.../tyre-pressure |
