06-09-2022, 08:33 AM | #1 |
Rep 139
While you're waiting- how to charge fast at home (US)
In case any of you waiting may be wondering about how to get the fastest home EVSE (sometimes mistakenly called a "charger")-- I installed a 240 VAC 60 amp breaker and hard-wired a Chargepoint flex in our garage, which has given me 11 kW charging reliably. I think that's the fastest level 2 (AC) charge an iX 50 will take.
The BMW-supplied one paired with a NEMA 14-50 plug and 50 amp breaker will charge at 9 kW, which is good too. Best video I've seen explaining all this is here
2022 iX XDrive50
previous 2019 Audi e-Tron, 2019 Porsche Cayenne e-hybrid 2017 MB E300, 2014 BMW 640i convertible |
06-09-2022, 08:39 AM | #2 |
Rep 4,539
Drives: 2022 iX xDrive50, DGM
Tom's channel has excellent analytical reviews of most of the current home "chargers" as well....
jsclarke99265.00 |
06-09-2022, 09:54 AM | #3 |
Rep 4
I was just researching this earlier today too.
Chargepoint seems like the way to go for max speed, but you need a hardwired install to pull more than 40 amps. That is the limit of nema 14-50 receptacle. https://www.evchargerreviews.net/bes...er-for-bmw-ix/ I'm not sure if these lists are helpful, seems like any J1772 wallbox with adequate amps will do the job |
06-09-2022, 10:31 AM | #4 |
Rep 139
Originally used plug, then hard-wired
Yeah I originally bought the ChargePoint Flex to schedule charge *start time* (which my e-tron didn't do) and I used a 14-50 plug.
Turns out, if using any cord, you are not allowed to draw more than 80% of the circuit rating (80% * 50A = 40A). Replacing that small cord with hard wired wire of sufficient gauge, and replacing the circuit breaker allowed me to setup the ChargePoint again using hard-wire/60A breaker settings, which got me 11 kW.
2022 iX XDrive50
06-09-2022, 10:36 AM | #5 |
Rep 165
The best charger to install is a Tesla HPWC (high powered wall charger). You can link them together and set them to match your AMP rating. Example - if you have 3 cars charging it will load balance each so as to not trip your breaker.
I have 3x Telsa HPWCs connected to a 100amp circuit. On my test drive the iX pulled 11KW. |
06-09-2022, 11:04 AM | #6 | |
Rep 3,079
Drives: 2023 iX M60 Oxide
Maybe things have changed but there are tons of reports on the forums about gen 3 overheating/throttling during charge. I think there's a hardware revision that has fixed that recently, revision "g" or something. My car will pull 11kw for about 20 minutes and then the unit flashes red and continues charging at 5kw. The second unit only charges a PHEV that is only capable of 3.6kw so I'm not sure if it does the same. It also took about 18 months for them to release load sharing feature which sort of killed a lot of confidence/enthusiasm, a feature promised at release. Functionality wise the main difference between gen 2 and 3 is WiFi, and gen 2 requires you hard wire a communication cable between the wall connectors to do the load sharing. Also, there are no smart features on the Tesla wall connectors, even though the gen 3 has WiFi it's mostly just used for firmware updates. They build it all into the car, so it's not very friendly/consistent as you switch vehicles. |
06-09-2022, 11:15 AM | #7 | |
Senior 1Addict
5164
Rep 2,426
Drives: BMW iX, Porsche GT4 RS
06-09-2022, 11:27 AM | #8 |
Rep 4,539
ChargePoint also and a beta tester for the software. Main hiccup right now is no option to select any iX as your personal vehicle in the app. Fix TBD....
TechCTU802.50 |
06-09-2022, 11:33 AM | #9 | |
Rep 1,097
I asked them to add the iX as well. |
Paladin15643.00 |
06-09-2022, 12:46 PM | #10 |
Rep 139
Do any of you guys know why the chargepoint app needs to know the vehicle? Is it just show it can show miles added given kWh used in a charge?
2022 iX XDrive50
06-09-2022, 02:27 PM | #12 |
Rep 4,539
06-09-2022, 02:42 PM | #13 | |
Senior 1Addict
5164
Rep 2,426
The app doesn't have the iX yet, so i just didn't put any car in my profile. |
06-09-2022, 04:39 PM | #14 | |
Rep 165
Have had them for many years without issue. Not sure about the smart features either - I let the car plan when to charge. |
06-09-2022, 04:46 PM | #15 | ||
Rep 3,079
The Gen 3 load sharing is a bit different though now, they recommend a breaker for each unit rather than just connecting them all to the same breaker, but you can still limit all units to a site peak. Not quite as useful in terms of just installing one run vs dedicated runs, but still helps you avoid tripping the main. |
06-10-2022, 10:26 PM | #16 |
Rep 1,702
Newb EV questions for everyone. What are the advantages of a hardwired system other than a slightly higher charge rate?
Same question on purchasing a smart charger like the ChargePoint vs just a standard cable? All of the metrics can be set through the vehicle and the vehicle app correct? |
06-10-2022, 10:44 PM | #17 | |
Rep 3,079
As far as hard wire vs plug in, higher current and cleaner install are the top reasons. Also it is said those large 14-50 receptacles are generally only rated for a limited plug/unplug cycles before the contacts wear out, but that's probably not an issue if you're not changing chargers often. I wouldn't whip out a portable charger and plug in daily though. |
Salespunk1752.50 |
06-10-2022, 11:03 PM | #18 | |
Rep 4,539
06-12-2022, 09:13 PM | #19 |
Rep 1,702
Good info, thanks.
FYI I tried to buy an iX or an i4M50, but no dice so I picked up a Mercedes EQS. The app is pretty advanced with geolocation, multiple schedules, ability to limit charge rate, etc. so that is where my question came from. Still may pick up an iX at some point when they are more readily available. |
06-12-2022, 09:23 PM | #20 | |
Rep 1,833
Drives: BMW iX Xdrive40 MSport
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
Salespunk1752.50 |
06-14-2022, 03:45 PM | #21 |
Rep 13
So for those of us with just one electric car (the IX) and a fixed rate plan with their power company, the supplied BMW adapter with a NEMA 14-50 in a 240V outlet will give us about 9kW charging with no added expenses, yes?
I was going to ask the same as Salespunk above. I just don't see the need for me with the above conditions to need to spend the extra money on a wall mounted charging solution just to get an extra 2kW of charging. |
06-14-2022, 05:36 PM | #22 |
Rep 299
With those connectors, the likelihood it causing some damage with frequent unplugging is greater, especially if that is your portable charger that you unplug and toss in the car frequently vs. one that is permanently mounted in your garage. Also, check with your power company, rebates for EVSE's might cover 90+% of the cost.
