06-15-2022, 06:26 AM | #1 |
Rep 7
Instrument Cluster Ambient temp
Just got my car on Friday and wondering if anyone has had an issue the the outside temperature not displaying correct temp? The center screen shows the current temp of 82 but the instrument cluster is only reading it's 64 outside.
06-15-2022, 02:27 PM | #2 |
Rep 154
Drives: 2022 M240i
Is not the Head unit an app that uses the internet to hit a website for temp data? whereas the instrument cluster will use a censor and you will always get slightly higher depending on the heat soak of the engine.
06-15-2022, 02:57 PM | #3 |
Rep 425
Pretty much. The instrument cluster is the sensor showing actual temperature, the iDrive is a weather app with internet data. You can tap on it and get the forecast.
