06-16-2022, 08:23 AM | #1 |
Rep 161
M50i brakes toasted after 13k miles
So my wife's X6 M50i with the M Sport brakes are totally done at 13k miles. The front's actuality wore through the wear sensor. I probably should have replaced the front rotors as well but they weren't that bad and the lease is up in April 23. I've never had a car eat brakes like this. Is this normal? My X70 M50i has about the same miles and pads are just fine.
06-18-2022, 01:31 AM | #2 | |
Rep 1,364
Rob |
07-03-2022, 11:31 PM | #5 |
Rep 8,830
Are the pads actually worn? My X5M triggered the pad warning light at about 14k miles which I thought was strange. After careful inspection the pads still had PLENTY material left but the front sensor corroded which was what triggered the warning in the dash. $30 new sensor fixed the issue for me.
Alan
alic9613.50 |
07-12-2022, 09:22 PM | #6 |
Rep 1,502
Im at 15K miles on my X6M and have plenty of brake left and I drive hard.
Your wife is 100% riding her brakes around town instead of just letting the car engine brake. |
07-15-2022, 12:46 PM | #7 |
Rep 161
The pads were definitely worn. Fronts were almost to the the metal. The rear brakes were about 75% worn. The brakes started squealing earlier this year and the dealer said she needed new pads and rotors all around. I said they are trying to rip you off and I'll look at them. Sure enough they were right.
Anyway, the brakes are still squealing sometimes. The rotors show some wear but they didn't look like they needed replaced to me. Looks like I might need to go ahead and order some rotors which are not cheap. |
07-15-2022, 01:52 PM | #8 |
Rep 3,274
makes sense to me probably its entirely caused by her driving habits. she probably guns that V8 when the light turns green then slams on the brakes when she needs to and on and on. just a guess.
07-15-2022, 02:06 PM | #9 |
Rep 161
07-22-2022, 10:10 AM | #10 |
Rep 1,952
Just had my M50i in today. 32k miles and I have 4mm rear and 5mm front. Rep recommended a change for the rears and said I could wait for the fronts. I would say my driving style is moderate.
07-26-2022, 06:12 PM | #11 |
Rep 6,881
Way back when I was learning to drive, I took a driver's ed class so I could get my license earlier. The instructor kept an empty glass milk bottle (remember when they would deliver milk!?) on his side of the footwell. Every time you knocked the bottle over, you'd lose 5-points for the day. The goal was to be smooth in accelerating, turning, and stopping. You didn't hold up traffic doing this either, and it was much more pleasant on any passengers, too. On my first BMW, it had about 75K miles on it when it was sold...still had a lot of brake pad left all around. Smooth is the key.
09-14-2022, 12:14 PM | #12 |
Rep 59
It's a big car. Keep in mind any of the driving assistants (cruise control, and frontal collision sensors) will apply the brakes.
Good for her for driving the car the way it was meant to be driven. BMWs need to be driven hard and not babied so much. Slap in some new pads and carry on. |
vinibabs35.50 |
09-14-2022, 12:24 PM | #13 |
Rep 161
She doesn't use cruise. Just drives it really hard. My X7 M50i goes in this month for a state inspection and I have 15,000 miles on it. I did go through two sets of tires (OEM and Winter) so I'll see what they say about my brakes.
09-14-2022, 03:39 PM | #14 |
Rep 262
She's def hard on the brakes! I just had my 10k service done on my 22 45e and they stated I had 10/32's left, meaning basically only 20% worn. While the 45e is heavier than the 50i, the regen brakes help a lot . . . I have m Sport and tow pack, so I think the rotors and pads are slightly bigger than those that don't; but the 50i likely uses the same larger ones I'd think.
10-01-2022, 09:36 AM | #15 |
Rep 49
I had all my pads and rotors replaced because they were squealing like a pig. Was done at about 20k miles and i dont even drive my x5 2019 40i that hard.
Ran me damn near $2k too replace everything at the dealer. |
10-01-2022, 09:49 AM | #16 |
Rep 2,057
I had "stuck" caliper that caused it to eat up front pad on one side. I didn't notice anything driving but dealer replaced caliper and obviously pads on both sides under warranty.
10-03-2022, 06:01 PM | #17 |
Rep 81
My wife's 2017 x5 40e had 80k on it and we never replaced the brakes and the pads were covered by the 3 year 36 miles factory warranty never got to use the brake pad warranty.
JerZBMerLife140.50 |
10-22-2022, 04:14 PM | #18 |
Rep 59
I don't know why no one mentioned it, but one thing I thought of:
Left foot braking. Maybe she's hovering her left foot over the brake pedal, and applying some pressure constantly. |
10-24-2022, 05:38 PM | #19 | ||
Rep 3,708
Even manual driver, left foot is trained to depress fast and hard, but release slow and soft for clutch operation. The exact opposite of how a brake paddle should be operated. Unless she is well trained on performance driving, highly unlikely an average driver will use left foot on brake.
2022 G05 B58/PHEV
+ a few very old BMWs |
10-25-2022, 07:31 AM | #21 | |||
Rep 2,057
