06-21-2022, 10:53 AM | #1 |
Rep 2
what tools should be in the boot
I have a 335D Xdrive 2017
what tools should be in the boot all I have is locking wheel nut & tow hook, nothing els thanks in advance |
06-22-2022, 02:09 AM | #3 |
Great Teacher
1124
Rep 1,314
Drives: 06 e91 325ix
Factory my f31 also has a screwdriver. The handle is effectively a 10mm socket, and the reversible shaft is Phillips/flat.
But that’s it, no wrenches, pliers, spark plug tube wrench, etc etc anymore like the old days.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
06-22-2022, 12:06 PM | #4 |
Rep 16,143
Makes you think that maybe BMW doesn't want you working on your car? Well, there's no maybe about it. OTOH if you have the skills to do your own work then you should have the tools as well.
06-22-2022, 01:25 PM | #5 |
Rep 890
The ol’ 2002 came with a nice proper toolkit. They covered most of what you’d need to do the care & maintenance yourself. Today the primary ‘tool’ included is a tow-hook.
And the owners manual showed you how to adjust the valves. Today it warns you not to drink the contents of the battery… lol The mechanically-inclined are a dying breed. |
Tommi_Mav65.50 |
06-22-2022, 03:29 PM | #6 |
Great Teacher
1124
Rep 1,314
My e34iT had everything there but the slip joint pliers… or it had them and I never used them.
The spark plug tool was excellent though. Used it every time I changed or checked plugs.
06-24-2022, 10:01 AM | #7 |
Rep 1,821
Just the one behind the wheel
What else can really be fixed on site besides tires? You aren't generally going to change your spark plugs on the side of the road are you? A scan tool would be good.. most of us have smartphones, so an OBD2 cable or bluetooth dongle and appropriate app. |
06-28-2022, 09:26 AM | #9 |
Rep 1,835
Bought an e39 jack, perfect slim jack for raising the F30. Then I have a small canvas tool bag with various road side tools including: mallet, needle nose plyers, Dynaplug tire repair kit, digital air pump, razor blades, gloves, extendable lug wrench, and a few other small bits and pieces.
all of this fits in the small compartment under the trunk floor. |
06-28-2022, 03:14 PM | #10 |
Rep 248
Drives: 1989 325i & 2014 335i
OP, my car came with a screw driver (Philips, blade, 10mm, 8mm), tow hook, and disposable gloves.
I also keep a tire plug kit (gloves, pliers, knife, plugs, plug tools), factory jack kit (breaker, jack, torque wrench), cigarette lighter air compressor, and an emergency kit (Band-Aids, water, cliff bars, water filter, rope, knife, whistle, emergency blanket, CPR mask, headlamp). All of this fits in the spare spot under the trunk floor of my sedan. I've never needed any of it. |
08-04-2022, 10:46 AM | #11 |
Rep 46
I just bought an F31, and the previous owner appears to have removed most of the items from the various storage compartments in the rear cargo area. I see numerous cutouts in the rigid foam that appear to be designed to hold very specific items.
What items came stock from the factory in the rear cargo area (North America market, in my case)? Thanks! |
08-04-2022, 03:36 PM | #13 |
Great Teacher
1124
Rep 1,314
Reversible Screw driver, locking lug socket. Towhook. That’s it.
And if you have the option for the boot divider it goes under the rearmost flap in the back. Or the cargo cover can go there. But not both at once and no place for the dog nets.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… Last edited by Onizukachan; 08-04-2022 at 03:43 PM.. |
CincyBearcats30.50 |
08-08-2022, 10:19 AM | #14 |
Rep 46
Thanks! I checked this weekend, and that's exactly what I have. I also found a first-aid kit with a BMW logo on it. I can only assume that the contents are the world's most expensive Band-Aids, unless, of course, Ferrari also equips their cars with said kits.
08-08-2022, 01:12 PM | #15 |
Rep 16,143
The band aids are because BMW thinks that BMW owners are putzes incapable of even wielding a screwdriver without cutting themselves. The lack of any other tools is their effort to keep you from doing worse damage to yourself. The tow hook is necessary have the car towed to your dealer for the slightest problem.
