06-29-2022, 07:01 PM | #1 |
BMW forever!
1395
Rep 2,428
M2 CS spoiler install on Competition
As a summer project, I want to get rid of the OEM M2C rear spoiler and replace it with CS one. I think it looks cool. Can anyone confirm the part number: 51-62-8-085-400.
Also how difficult is it to replace and install? Has anyone done it here successfully and are you happy with it? It looks like we also need to buy the Adhesive Tape Rear Spoiler, M2 CS - BMW (51-62-8-085-401) separately, adding to the cost. Total price is around $800. I am thinking to also install the rear CF diffuser but that's a separate topic. Thanks in advance.
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
06-29-2022, 07:24 PM | #2 |
Rep 211
Drives: 2021 F87 M2 Competition
Used to fit the M Performance CF ones to vehicles quite often. It's been a few years since I've done one, but the OEM one comes off fairly easily with a plastic trim tool and then peeling off the remaining adhesive. You'll want to make sure that surface is completely adhesive free before installing the new spoiler. We used to use a bonding adhesive called "Betalink", tube of black stuff that is sticky as hell, and it also came with a bottle of adhesive remover, same brand (looks like bimmerworld has it in stock, https://www.bimmerworld.com/Body-Aer...stall-Kit.html). But yeah, you just put a single bead of that stuff along the length of the spoiler and press it down into place. Don't over apply the stuff as again, it gets messy real quick. Then just use some tape to hold in down in place and leave it for a day to dry.
Can't confirm if the M performance spoiler is the same one as the CS one, but the application process would be identical.
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family) |
buckybadger1394.50 Bumpinjeep5664.50 |
06-29-2022, 07:58 PM | #3 |
Rep 7,340
It depends if your OEM M Perf spoiler was attached at port or dealer. If at port, it could be attached with Betalink or similar and be extremely hard to remove. That's what keeps me from attempting the same mod.
Fred Conoway365.00 |
06-29-2022, 08:32 PM | #4 | |
Rep 11,669
The good news is that M2C lip is not an optional port install item. They are standard install at factory and are trim tape not betalink.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
06-29-2022, 08:55 PM | #5 |
Rep 7,340
Are you sure? I thought all M Performance options on the Monroney were port installed in the US?
06-29-2022, 10:16 PM | #6 | |
Rep 211
And yes, can confirm that Betalink is a PITA to work with
chris7197392.00 |
06-29-2022, 11:38 PM | #7 |
Rep 7,340
Ah yes, I misunderstood the OP and thought he had an M Perf spoiler to remove.
06-29-2022, 11:45 PM | #8 |
Rep 32
Simple and easy removal and install. I did this 2 weeks after I picked mine up this time last year. Part number is correct also buckybadger
06-30-2022, 11:17 AM | #9 |
Rep 3,257
Removing the tape from the previous spoiler was a bit of a pain too. Thought I'd be done in an hour, ended up taking about 3 just to remove the tape. I can't imagine what removing betalink would require.
06-30-2022, 11:33 AM | #10 |
Rep 197
This will remove the adhesive on the trunk in minutes. I used it when I installed my carbon spoiler and fully endorse it. Just go light and slow and it takes the adhesive off very quickly and leaves your trunk looking new.
3M Eraser Wheel https://www.amazon.com/Adhesive-Remo...NsaWNrPXRydWU= |
06-30-2022, 01:56 PM | #11 |
Rep 1,563
I’ve been thinking about this project as well. A lot of good tips posted. Thanks!
buckybadger1394.50 |
06-30-2022, 02:29 PM | #12 | |
Rep 11,669
These things work great!
06-30-2022, 03:04 PM | #13 | |
Rep 3,257
SilverScotty321.50 buckybadger1394.50 |
06-30-2022, 06:13 PM | #14 | |
BMW forever!
1395
Rep 2,428
2020 BMW X5
06-30-2022, 06:15 PM | #15 | |
BMW forever!
1395
Rep 2,428
Maybe for the CS spoiler I need to buy the part above? Links: https://www.getbmwparts.com/oem-part...er-51628085400 https://www.getbmwparts.com/oem-part...cs-51628085401
2020 BMW X5
06-30-2022, 06:16 PM | #16 | |
BMW forever!
1395
Rep 2,428
Let's do it! I am looking to buy the parts this weekend.
2020 BMW X5
IcewaterPete2212.50 |
06-30-2022, 09:10 PM | #17 | |
Rep 211
06-30-2022, 10:46 PM | #18 |
Rep 3,826
I would never use beta link on anything, with properly applied VHB tape there's no reason to.
chris7197392.00 buckybadger1394.50 |
07-01-2022, 04:38 AM | #19 |
Rep 28
Good quality 3M tape and some adhesion promoter (not absolutely needed if the surface is good and clean) has always been plenty in the past for me. Even that was a fight to remove again sometimes. Betalink seems a bit overkill.
allinon724960.50 buckybadger1394.50 |
07-01-2022, 07:17 AM | #20 |
Rep 506
I removed the M Performance carbon fiber rear spoiler and installed the CS Spoiler. I used 3M VHB double sided tape after polishing the surface with a light compound. No issues at all.
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2 |
07-01-2022, 11:02 AM | #21 |
Rep 3,844
I used fishing line to remove the original spoiler. I think normal 3M double sided tape has plenty of strength for that application.
07-01-2022, 12:09 PM | #22 |
Rep 5,731
Drives: 2019 M2 Competition
I paid $150 to have EAS do it because i hate dealing with tape removal.
