07-09-2022, 06:07 PM | #3 |
Rep 1,104
I figured out how to silence the rattle with a little bit of soft velcro.
However, in doing so, I may have cracked a tiny piece of the door lock bezel cover underside clip. I would appreciate help if someone can help me identify the part number for this replaceable piece. See pictures. Thanks! |
07-09-2022, 06:17 PM | #4 | |
Rep 120
I think u push door pin not far enough. Door pins of my car when it locked is very flat, not emergent like that. U should buy 'M' door pins around 50$ to replace it |
07-09-2022, 06:19 PM | #5 |
Rep 1,104
The door pins are unlocked. No issues with that. I am talking the actual bezel surround cover. Not the pin itself. Picture two shows where it is raised towards the windows side. Looking to replace the bezel as one clip is damaged under.
07-09-2022, 06:25 PM | #6 |
Rep 120
Hehe no idea with bezel, but i think u should ask any shop out there, they will give u exactly what u want. Dont have many people replace it on G42 this time
xcelir8bmw405.50 |
07-09-2022, 06:29 PM | #7 |
Rep 1,104
Pretty sure it's this: 51417447304
https://parts.bmwmonterey.com/p/bmw_...417447304.html https://www.jakesweeneybmwparts.com/...417447304.html |
07-09-2022, 06:47 PM | #8 |
Rep 1,104
Ordered, hopefully it solves my problem.
Other BMWs in the past have had the same issue and that's how I stumbled on a fix, except the bezel we have is made differently. |
07-09-2022, 10:16 PM | #9 |
Rep 177
I had the same problem on my wife’s 2015 435 and found an easy fix
First, CAREFULLY pry up the bezel from the pin Then wrap about an inch of black electrical tape around the base of the pin. Should solve the problem Last edited by bobkat09; 07-10-2022 at 01:28 PM.. |
xcelir8bmw405.50 G42M240135.50 |
08-06-2023, 07:15 AM | #12 |
Rep 141
Update: I removed the trim around the lock pin and used the soft side of velcro around the inside. The rattle is completely gone! Highly recommend. There are many youtube videos on this.
08-07-2023, 01:13 PM | #13 |
Rep 107
08-07-2023, 03:31 PM | #14 |
Rep 2,118
08-09-2023, 02:15 PM | #15 |
Rep 267
