07-11-2022, 12:15 PM | #1 |
Rep 47
Steering wheel vibration and Cross Traffic Alert
Hey guys. Before I go to the dealer I wanted to run this by you.
I have a 22' X3M Comp. 5k miles. I have done some programming with Bimmercode like my prior vehicles. I am having an issue. 1. When blind spot alert kicks in I can barely feel the steering wheel. Its such a small vibration that I almost never feel it. Setting is set to strong already. 2. When cross traffic alert should kick in I don't get a sound alert. Sometimes that cross traffic alert is not even working like my other car which is a 2020 Grand Cherokee. That one gives me a heads up way in advance. Is it something with Bimmercode? There wasn't any coding related to these things. Thanks, |
07-11-2022, 02:06 PM | #2 | |
Rep 562
07-12-2022, 07:57 AM | #4 |
X3M Comp is a beast
89
Rep 171
BMW Cross Traffic Alert is a joke. It is nowhere near the other brands. KIA, Hyundai, Jeep, Volvo all have better systems. BMW should be ashamed of the Cross Traffic Alert system. X3mc is horrible and my M340I was just as bad. I would never trust it like I do our Jeep and Kia that actually work like it supposed too. Now the applying the brake when backing out of the garage sure does work.
07-14-2022, 01:50 PM | #6 |
Rep 562
I only have mine to compare it to, but yeah, it's a weak vibe. Some others have said theirs was weak, too. To be honest, I didn't know these had cross traffic alerting, I've never been in a situation where it would have activated, or if I was, nothing happened - like what you are saying.
07-19-2022, 07:42 PM | #7 |
Rep 31
Same here, light vibration for blind spot.
I've had the cross traffic alert beep at me a few times, from my experience it only beeps when you are moving/letting off the break. If not moving you will only see the red flash on the idrive camera. It will flash red on the side of potential impact, let go of the break then it will beep. Not sure if it matters, I have the driving assistant pro. Haven't tested this, just what I observed to be happening. |
07-20-2022, 09:15 PM | #8 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3560
Rep 4,245
The X3 and your X5 operate differently. The X5 has a vibrator in the steering wheel. The X3 2020 and up have the vibration feature built into the steering rack. No vibrator in the steering wheel. The vibration is much more subtle now especially if you're comparing to an F15 X5. Those things straight up buzz and vibrate hard. It's normal for the X3
Kevin_The_Clean13420.00 |
07-25-2022, 04:32 PM | #9 | |
Rep 47
07-25-2022, 04:35 PM | #10 | ||
3560
Rep 4,245
06-03-2023, 07:40 PM | #11 | |
Rep 322
06-03-2023, 10:26 PM | #12 | |
3560
Rep 4,245
08-22-2023, 10:13 PM | #13 |
Rep 11
Hello everyone, not sure if this helps you but I dropped my 2019 X3 at the dealer yesterday for a similar issue. They replaced the vibration motor and test drove the car. The technician concluded that the vibration is still weak. They are reaching out to engineers at BMW-NA for guidance on how to proceed with the repair. The service advisor mentioned to me when I dropped off the car that he’s had other cars come in for the same issue. A service bulletin I found notes a possible need for both the vibration motor as well as a module and possibly a software update. I’ll keep you posted. They have me in a 2023 X3 loaner at the moment and the vibration is quite strong on this one so I have hope.
redbullfan356.00 |
08-23-2023, 11:34 AM | #14 | |
Rep 689
Drives: 22 TR X3MC
2022 X3M Comp
2013 335i xDrive (Sold) |
Moonkitty1.50 |
08-25-2023, 10:23 PM | #15 |
Rep 11
Update:
The dealer replaced the actuator motor which resulted in continued weak vibration of the steering wheel. After consulting with BMW NA, they now want to compare a similar car, either 2018 or 2019 X3. I’m waiting for them to locate one and have my car back temporarily. Upon driving the car myself I found the vibration a tiny bit better but it’s not consistent. It goes in and out, still very week. I plan on taking the car back next week to give the dealer time to locate another one to compare with. I’ll keep you updated. |
09-05-2023, 05:13 PM | #16 |
Rep 11
Spoke with the dealer today. They are backtracking. The technician stated in writing that the vibration is weak however now the service advisor is saying that it’s normal. WTF?
09-05-2023, 06:15 PM | #17 | |
Rep 11
Wish me luck. |
