Tune detection and Code readers
12-15-2008, 07:30 PM | #1 |
Rep 1,948
Hey Guys,
I read somewhere but couldn't find it after searching.... The question is, which readers out there can read the BMW DME? Specifically, if the tune detection code was tripped? I believe the 2 were GT1 and Autologic? Am i correct? |
12-15-2008, 07:46 PM | #2 |
Rep 1,654
Drives: AW M3
Yes. GT1 or an Autologic scanner will show all faults stored and give you the ability to clear them...
What your looking for if the warranty code is tripped is "tuning protection" in the form of a limp (reduced power mode) Those are the exact words when it shows on the GT1 |
12-15-2008, 07:46 PM | #3 |
Rep 5,780
Only OBDII related codes which amounts to probably less than 25%. I am hoping, and will be following up next week, that AutoEnginuity will have their software ready which can read and reset all BMW specific information.
12-15-2008, 07:48 PM | #4 | |
Rep 1,654
Drives: AW M3
It will show you all of the faults tripped by your car and even solutions to the problems and also the ability to clear them |
12-15-2008, 07:48 PM | #5 |
Rep 5,873
Drives: m
Uh, so a jb3 can be detected with the proper machine?
12-15-2008, 07:52 PM | #6 |
Rep 1,654
Drives: AW M3
Nope
only if you run a pre29.2 version with a 29.2 in the car That'll hide it pretty well specify to terry you have a "post 29.2 dme" and the code wont be tripped only downside is maybe -5/10wtq in the low end |
12-15-2008, 07:52 PM | #7 |
Rep 6,020
Drives: MINIVAN
yes and no... if its installed improperly and trips a code (as for any piggyback system) it can be detected... otherwise i dont think it can be.
12-15-2008, 07:53 PM | #8 |
Rep 5,873
Drives: m
Well oh put up a disclaimer before all this technical talk. You scare us simple folk.
12-15-2008, 07:53 PM | #9 |
Rep 6,020
Drives: MINIVAN
yeah and that
12-15-2008, 07:53 PM | #10 |
Rep 5,780
True, but those are not as readily available to the comsumer. For instance, a GT1 costs over $1000 from what I recall (could have a foggy memory though). I was referring to PC based application and should have clarified that.
12-15-2008, 07:54 PM | #11 |
Rep 6,020
Drives: MINIVAN
pre29.2 = older 335's post 29.2= new 335 or people who have had their software updated by bmw
12-15-2008, 07:54 PM | #12 | |
Rep 1,654
Drives: AW M3
hes asking if GT1 or autologic can check it but to clarify: scalbert is correct, OBD-II readers will barely show anything |
12-15-2008, 07:58 PM | #13 |
Rep 6,020
Drives: MINIVAN
is this the thing you guys are talking about ?
http://www.autologicco.com/pocketline/pocketobdpro.shtm
12-15-2008, 09:22 PM | #14 |
Rep 2,842
I contacted the manufacturers of the Autologic system and they claimed that their diagnostics can read and clear any code that the dealer diagnostics can detect.
I have seen a local private BMW mechanic read the detection codes with an Autologic and clear them at the press of a button. They were descriptive not numeric codes and they specified "implausible air/fuel" as well as "wastegate duty cycles exceeded". So I think as far as dealer level diagnostic detection is concerned, the codes are erased and invisible to the dealer. However, I still believe that raw data is stored beyond this level of detection and BMW can download and read stored FASTA data within the ECU to determine that certain performance parameters have been exceeded. However, this is just my personal opinion and may not be correct. .......I certainly hope so. |
12-15-2008, 09:23 PM | #15 | |
Rep 1,948
12-15-2008, 09:24 PM | #16 |
Rep 1,948
I did email them and they are still in the waiting phase so not being release till next year sometime according to their reps.
