bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) App, Nav, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      07-12-2022, 08:38 PM   #1
hpaco
Mexico
30
Drives: Mini Cooper S
ID8 Plus vs Pro
Does anybody knows the difference between BMW Live Cockpit Plus and BMW Live Cockpit Professional (6U3)?
There is not much info in BMW and my CA doesn’t know the difference, in the configurators from Spain and uk it shows the same screen whether Pro is selected or not, the configuration for Mexico doesn’t has the M240i yet.
All I have found about is the Pro having the HUD, it’s there any other difference? It’s a $1500 USD upgrade and I think is too much for the HUD only.
      07-13-2022, 03:30 AM   #2
ZacMatic
Drives: 2022 BMW M240i xDrive
Live Cockpit Plus has analog gauges with a smaller screen in the center of the instrument panel. Live Cockpit Pro has a 10" screen for the instrument panel with no analog gauges.
      07-15-2022, 10:50 AM   #3
hpaco
Mexico
30
That’s right for ID7, for ID8 these are the images shown in the 2023 configurator (not US):
I’m not sure what’s $1500.00 buys you. The only difference I have found is the HUD, but info is not clear.
      07-15-2022, 12:17 PM   #4
harcos
Drives: 240i xdrive
If this thread can help you :
https://g42.bimmerpost.com/forums/sh....php?t=1937892
Here in Europe for 240i Xdrive :
Professional (please translate) ::
Le BMW Live Cockpit Navigation Professional avec grand Curved Display ajoute au BMW Live Cockpit Navigation Plus un Head-Up Display tout en couleurs. Il projette des informations de conduite telles que la vitesse ou les indications de navigation dans le champ de vision direct – pour une meilleure vue d'ensemble et plus de sécurité.
Les avantages en un clin d’œil ;:
Le Head-Up Display projette les informations pertinentes dans votre champ de vision direct
Grand Curved Display pour l'affichage des informations
Fonctions améliorées ou étendues automatiquement over the air
Activation automatique des paramètres personnels
Le BMW Live Cockpit Navigation Professional augmente la sécurité pendant la conduite. Le Head-Up Display affiche directement les informations utiles dans votre champ de vision. Vous pouvez donc pleinement vous concentrer sur la circulation et réduire votre distraction. Affichage en couleur, coloration légère, affichage jour et nuit et hauteur d'affichage réglable garantissent une lisibilité exceptionnelle.
Le BMW Live Cockpit Navigation Professional comprend en outre les composants du BMW Live Cockpit Plus. Le système de navigation vous permet d'arriver à destination plus rapidement et en étant mieux informé. Le système calcule l'itinéraire en temps réel et offre d’autres possibilités et vous indique également les lieux intéressants dans les environs.
Le BMW Curved Display sans cadre présente les informations sur un grand écran et de manière claire. Il réunit un combiné des instruments entièrement numérique de 12,3'' et un Control Display tactile de 14,9''. Le système multimédia comprend une interface Bluetooth®/Wi-Fi ainsi que deux prises USB pour le transfert de données et la recharge de périphériques mobiles.
Le BMW Operating System 8 vous permet de commander de manière plus fluide les fonctions du véhicule. Vous pouvez commander le système avec votre voix, l’écran tactile ou via le BMW Controller. Votre BMW ID vous permet d'enregistrer vos préférences personnelles dans votre propre profil utilisateur. Avec le Remote Software Upgrade, votre BMW est automatiquement maintenue à jour. Le logiciel embarqué bénéficie de fonctions améliorées ou avancées over the air, sans que vous ayez besoin d’agir.
Plus :
Des possibilités de confort à l'inter******ion en passant par la navigation : Le BMW Live Cockpit Navigation Plus séduit par ses nombreuses fonctions pratiques.
Vous arriverez à destination plus rapidement et mieux informé grâce au système de navigation. Le système calcule l'itinéraire en temps réel et offre d’autres possibilités et vous indique également les lieux intéressants dans les environs.
Le plus simple est de contrôler le BMW Operating System 8 par saisie vocale. Le BMW Intelligent Personal Assistant permet de contrôler de nombreuses fonctions du système de navigation et multimédia intégré par commande vocale. Si vous préférez une gestion manuelle, vous avez alors le choix entre le BMW Controller éprouvé, les éléments de commande au volant ou la commande tactile sur le Control Display.
Un Curved Display de grande dimension qui réunit un écran d'instruments multifonctions de 12,3" et un Control Display tactile de 14,9" assure une représentation synoptique. Le système multimédia comprend une interface Bluetooth®/Wi-Fi ainsi que deux prises USB pour le transfert de données et la recharge de périphériques mobiles.
Votre BMW ID vous permet d'enregistrer vos préférences personnelles dans votre propre profil utilisateur. La configuration individuelle est ensuite automatiquement activée via la clé du véhicule, la Digital Key en option ou par sélection de l’utilisateur sur le Control Display.
Grâce au Remote Software Upgrade, votre BMW est automatiquement maintenue à jour. Le logiciel embarqué bénéficie de fonctions améliorées ou avancées over the air, sans que vous ayez besoin d’agir.
      07-29-2022, 08:29 AM   #5
spansar
Drives: F30 M320d, CANCELLED G42 M240i
Live Cockpit Plus £0
The BMW Live Cockpit Plus features a display cluster consisting of a fully digital 12.3" instrument display and a high-resolution 14.9" control display. Further features include:
- BMW Operating System 8 with variable, configurable widgets that display information in real time
- Navigation function
- Intuitive operation options:
- BMW Intelligent Personal Assistant (natural voice control by voice command "Hey BMW")
- touch operation on the control display
- iDrive Touch Controller with turn and press function
- direct selection possible by touch-only operation (e.g. map view in navigation widget)
- direct access to 3rd-party apps (smartphone integration)
- driver profile: enables storing personal settings (seat, air conditioning, navigation, entertainment, etc.) in a driver profile and connecting this with a (digital) key. Upon activation of the profile via the key or by selecting it on the display, the desired settings are adopted automatically. Prerequisite for use: BMW ID (ConnectedDrive account).
- tuner with diversity reception and RDS
- 1 x USB type A with data transfer and 1.5 Ampere charging function in the centre console
- 1 x USB type C with 3 Ampere charging function in the front centre armrest
- Bluetooth / Wi-Fi interface
- 4G LTE connectivity: hard-wired SIM card with 4G network in the vehicle for keeping the customer mobile (only for ConnectedDrive markets)
- Remote Software Upgrade: enables regular over-the-air upgrades of software for the entire vehicle, incl. quality improvements, extensions of functionality and new features.
Available as standard.
BMW Live Cockpit Professional includes all the contents of BMW Live Cockpit Plus plus a full-colour Head-Up Display with configurable HUD contents.
Benefits at a glance:
Head-Up Display projects relevant information directly into your field of view
Available as part of the Technology Pack (£1250)
The Technology Pack is made up of the following 3 options:-
INCLUDED IN THIS PACKAGE.
Parking Assistant
Storage for wireless charging
      10-29-2022, 10:21 AM   #6
thecrimsnchin
Drives: 230ix
Pretty sure it's just the heads up display that you're adding for iDrive8 for the $1500. BMW promotional materials for iD8 aren't updated for cockpit plus/pro. I didn't option it.
g87
