12-16-2008, 02:07 PM | #1 |
Rep 1,149
I need Mac Pro help
Im not making fun of the other threads. The past couple of days when i shut down my macpro, the dock and top navigation bar disappear and it just shows my background. I have to hold the power button to shut it down. Has this happened to anyone else? I don't wanna call apple support because they're idiots.
12-16-2008, 02:09 PM | #3 |
Rep 7,433
sounds like a program isn't quitting
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
12-16-2008, 02:11 PM | #5 |
Rep 1,149
what do you think it might be? I usually have final cut pro running most of the time. Ohh and i have littlesnitch too but i doubt its that because of that, it worked fine before.
12-16-2008, 02:12 PM | #7 |
Rep 5,945
I'd help you, but you know....MACs are supposed to be intuitive, so I can't use them =/
I have to deal with PCs...you know...the hard stuff -_- if it were a PC, generally you have a task manager where you can see what is running and what might be causing the problem, MACs? no clue. |
12-16-2008, 02:15 PM | #8 |
Rep 7,433
It could also be the OS hanging up, maybe you updated software recently and something went wrong
-Brian
12-16-2008, 02:18 PM | #9 |
Rep 5,389
Drives: 08 JB E92 M3
Mac = Ftl
Pc = Ftw |
12-16-2008, 02:20 PM | #10 |
Ez tur90
202
Rep 3,193
Wusup Taron. It could be from Final Cut Pro, when I installed in mine it would take a good 10 minutes to bootup and shutdown. Which Final Cut do you have, and are you importing footage from a HD cam?
12-16-2008, 02:22 PM | #11 |
Rep 1,149
do you think it might be because i've been running the shit out of it for the past week? It was rendering a 3D animation for like 3 nights, and ive been editing a video during the day lol. Is there like a defragment program for leopard? I know there was one on xp and sped it up pretty well
12-16-2008, 02:24 PM | #12 |
Rep 1,149
I have FCP 6 and i import the footage from a Sony HDV deck. I have the deck connected to a broadcast monitor and those 2 are on most of the time too. Ive been running this setup for a while now i dont know why this just started happening
12-16-2008, 02:31 PM | #13 |
Ez tur90
202
Rep 3,193
It could be that you were editing it for 3 days but I highly doubt it, once I transferred my footage to an external hard drive it started booting up normally.
12-16-2008, 02:45 PM | #15 | |
Rep 3,807
Drives: Retired 2017 F87 M2
Try zapping your PRAM by restarting your computer and hold down command+option+P+R you should here a sound, hold it down till you hear the sound 3x then let go. See if that fixes your problem.
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue| |
12-16-2008, 02:46 PM | #16 |
Rep 955
Download Onyx and run the tests...it'll tell you whats up. Also, shut down your computer and reset the PRAM and such (Onyx will help you). As long as Onyx says your good, you'll be fine. Otherwise, it'll tell you what the problem is. Good luck.
http://www.titanium.free.fr/pgs2/english/download.html Edit: Haha I got sniped by sniper 6
12-16-2008, 02:52 PM | #17 | |
Rep 1,149
12-16-2008, 04:42 PM | #19 |
Rep 3,856
Drives: Jerez E90 M3
Just leave it, its part of the OS shut down procedure. Although if it sits like that for over 30 mins, check software update and such.
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 | |
12-16-2008, 04:49 PM | #20 | |
Rep 1,414
Drives: 2008 BMW 550i
This program is like pressing CTRL+ALT+DELETE for PCs, it will give you a list of whats running on your macbook, and where your resources are being used up, etc. . .Sort by %CPU and you can see what programs are dominating your memory, and preventing your system from shutting down.
12-16-2008, 06:37 PM | #21 |
Rep 7,433
you can also go to disk utility and run permissions tests and stuff. i would try that too
-Brian
