08-19-2022, 01:33 AM | #1 |
Rep 75
E30 Suspension setup
Hello hope all is well,
I have recently acquired a 1991 318is, my intentions are to get the car set up for the track, and I wanted to reach out and see if there is anyone who has really dialed in a solid suspension setup, everything on the car is stock so a lot of things are expected of a refresh. I am basically looking for people's track setups and what they have done to their E30s. Thank you! |
08-19-2022, 01:51 PM | #2 |
Rep 145
Are you looking for a real “race” setup or more of a track day/Hpde setup?
The standard spec e30 racing stuff is decent and cheap, or even doing ground control setup isn’t much more money. It really depends on what you are looking to do with it.
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
c18209.00 StradaRedlands4970.00 |
08-19-2022, 02:18 PM | #3 |
Rep 945
Drives: e92 335i, f22 m235i, e30 325is
Mine has H&R race springs on B8s. H&r Sways, RD front strut bar.
She stays really flat. Even in transitions, and if the rear steps out, it's no drama. (full disclosure, the sub200hp powertrain probably contributes to this as well. Also, I only DD my car, though it's been healthily driven in non DD ways. Nothing on the level of track abuse though) Edit: probably should mention, mine has an LSD which also contributes a good amount to its handling
08-19-2022, 03:13 PM | #4 | |
Rep 75
Basically something for the track, over time I'll eventually push it to full blown race car. Thank you |
08-19-2022, 03:14 PM | #5 | |
Rep 75
ky0u1068.50 |
08-19-2022, 08:57 PM | #6 | |
Rep 945
Other than that, the only thing i can think of is, as a DD, the set up kinda sucks. it's pretty conservative compared to other builds out there, but between the spring rate and the shit road surfaces out where I am, it's quite the spine abuser. Hell, sometimes even rolling over a lane reflector sends a shock through my teeth
c18209.00 |
08-19-2022, 09:22 PM | #7 | ||
Rep 75
08-20-2022, 12:17 AM | #8 | |
Rep 145
Starting with a 318is you should look for the bigger LSD from a 325i auto. They are the same ratio 4:10, as your existing 318is diff.
c18209.00 |
08-20-2022, 04:13 AM | #9 | ||
Rep 75
08-20-2022, 04:03 PM | #10 | |
Rep 3,214
08-20-2022, 05:00 PM | #11 |
Rep 109
H&R race springs and Koni dampers. Konis are a far superior damper to the Bilsteins due to the ability to adjust the rebound. For the rear I'd suggest the 8042-1134 Koni. It is a double adjustable (compression and rebound) shock originally built for the Fox-body Mustang. The ability to adjust compression for the track is huge.
The rear Koni also has a shorter body so it will work much better with a lowering spring such as the H&R race spring and won't be on the bump stop all the time. To use the front Bilstein B8 with a lowering spring, you really should cut the internal bump stop down, otherwise you'll be riding the bump stops with those race springs. IMO - The ultimate non-coilover suspension combination is as follows: 1) Turner J-Stock springs (680lb front / 1026lb rear spring rates) 2) Bilstein Group N Motorsport dampers (Front = 34-046296 Rear = 24-000624) 3) BMW OEM camber corrected top mounts (31331139484) 4) TMS fixed camber plates 5) 22mm front sway bar 19mm rear bar This assumes you have 51mm front strut housings. This setup is not cheap but far superior to anything Ground Control offers. Your car will handle like a go-kart. There won't be much that will be able to touch it in the corners (assuming you know how to drive it through the corners - trail braking will be important to get it to rotate but that is more of an overall E30 chassis thing). |
08-20-2022, 10:29 PM | #12 | |
Rep 75
08-20-2022, 10:36 PM | #13 | |
Rep 3,038
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Damn I miss that car! |
ky0u1068.50 |
08-22-2022, 03:09 PM | #14 |
Rep 945
It's a hoot. I love my e92, it never fails to put a smile on my face when i put my foot down (and then wipe it off with a gong right after...jk no gongs...cuz something in my MOST loop is borked). But I know it will never hold a candle to the feeling of ripping the e30 through the twisties
08-22-2022, 04:54 PM | #15 |
Rep 1,489
My street E30 is ground control that have e30 m3 swaybar links welding in place vs using control arms. It also has Eibach sways.
My e30 M3 is full J-Stock with matched rate Bilstein re-valved shocks. A bit stiff but the car is flat in corners. I don't use the car nearly as much as I used since relocating back to Mass. When I was in NoVa I used to daily it as the roads were so much better. |
ky0u1068.50 StradaRedlands4970.00 |
08-22-2022, 07:04 PM | #16 | |
Rep 3,038
10-25-2022, 09:54 AM | #17 | ||
Rep 10
10-27-2022, 05:59 PM | #18 | |||
Rep 75
10-28-2022, 10:50 AM | #19 | ||
Rep 9
