08-22-2022, 09:45 AM | #4 |
Rep 39
Probably around 3-4 yes but it's worth it to test the E85 so you can know exactly how much ethanol is in the tank.
If you get a JB4 you can send in your logs to Burger Motorsports and they will review them, it helps if they know how much E is in your tank in case they recommend more or less. Main thing with E30 is the risk to run a little lean, just send in your logs to BMS, they'll see it and let you know. But yeah its basically safe. I daily drive JB4 map 5 on E30 |
08-22-2022, 10:58 AM | #5 |
Joint Chiefs of Staff
24342
Rep 191,129
E30, the number of gallons depends on how much fuel you have in the tank.
Add 4 gallons to an empty tank will be a lot more than E30. I usually run it until the gas tank is empty, then add E30 and 91/93. Please note, that the fuel-it kit is handy since the ethanol mix at gas stations is never accurate,
08-22-2022, 12:30 PM | #6 | |
Rep 461
08-22-2022, 02:15 PM | #7 | |
24342
Rep 191,129
It allows you to check the exact Ethanol mix using an app on your phone.
08-22-2022, 06:16 PM | #8 |
Rep 461
Sweet! Thanks!
08-22-2022, 08:14 PM | #9 |
24342
Rep 191,129
