hooking up oil pressure gauge: need some help
12-20-2008, 02:09 PM | #1 |
Rep 1,003
I recently bought oil pressure and boost gauges. They are the Defi racer gauges that kenntona also has in his car. The directions are just diagrams so I'd appreciate some help from people that have installed this before.
the boost is straight forward, the oil pressure is what i need help with. According to Defi's directions, i need to buy a commercial sensor attachment and a "commercial conversion adapter". We dont have the same setup on our cars as the diagrams show so I need some DIY help... thanks guys hov |
12-20-2008, 02:11 PM | #2 |
Rep 4,726
pretty much anywhere on the oil filter housing you can put a sensor and or adapter in. Those two nuts above where the oil cooler is may suffice.
12-20-2008, 04:42 PM | #4 |
Rep 4,726
Honestly you shouldn't be doing it yourself if you need to be asking, and I'm not saying that to be a dick like most of the things I say.
12-20-2008, 05:22 PM | #5 |
Rep 405
Pretty straight forward. He asked for help, whether he should install it himself.
O-cha is correct, I would tap it off the oil filter block. I don't know how the 335i is setup, but I know it is located in the front of the engine, right near the hood latch. Got a link to what pod you'll be using? Or to the other members? It is my understanding that the Defi Racer Pressure gauge is electrical, which uses an oil pressure sender/sensor..? In this case, you have two options: 1) Get an oil filter adapter block/plate AKA Sandwich plate. I am not sure what size BMW uses, but most/all cars use only 2 different sizes. This simply attaches to the oil cooler/filter plate where the filter goes, and teh filter then attaches to the sandwich plate. You screw the OEM sensor into this sandwich plate, as well as your new OP sender/sensor. See pic: 2) You just get the right fittings and tee the factory sensor. This is probably the simplest way. Locate the factory OP sensor wire, usually on the oil filter plate/cooler plate. Unscrew this, go to Ace Hardware, or anywhere that has metric fittings, and find a tee that will screw into the factory location. Screw the factory sensor to one end of the tee, and the Defi sender/sensor to the last end of the tee. You're basically wanting to TEE into the oil line coming off the oil filter housing, just like installing a boost gauge. Hope this makes sense.. here's a basic diagram: Sizes are probably about the same.. I did this in my Mazdaspeed 6, and came out great. |
12-20-2008, 06:08 PM | #6 |
Gixxer Man
14
Rep 599
The unit above looks a bit more complicated from the one I used on my Evo but the theory is the same. You need an adaptor that will sandwich between the oil filter and its housing.
Stable: 2008 E90 335i JB3 etc..., 2006 Range Rover HSE, K7 GSX-R 600
Former Stable: 2008 MB C300, 2007 Chevy Avalanche, 2006 Evo IX (544awhp), 2005 Sti, 2003 Evo... |
12-20-2008, 06:48 PM | #8 |
Gixxer Man
14
Rep 599
Well that sucks. In that case you may have to tap into the oil pan That's going to suck
12-20-2008, 06:50 PM | #9 |
Rep 1,283
12-20-2008, 06:54 PM | #10 |
Rep 4,726
He was probably thinking oil temp.
12-20-2008, 08:20 PM | #11 | |
Gixxer Man
14
Rep 599
12-21-2008, 12:04 PM | #13 |
Rep 1,003
thanks for all the help. yes im familiar with all the components under the hood. I've just never installed gauges so thats why i turned to you guys on the forum. I'm sure there are probably different ways to do it but thats where i need the advice for what is the simplest method on our car.
01-09-2009, 03:00 PM | #15 |
Rep 164
your best bet is to pull one of the plugs that are near the oil filter and get an adapter plug to put in there. the adapter plug will have the same threads as the plug you pulled out, but it will also have a hole drilled in it with the proper 1/8 npt threads to connect your oil sensor/sender.
JPSIMON's personal mechanic
01-09-2009, 03:27 PM | #16 |
Rep 1,003
oh so its just a plug i pull out of the oil filter housing? i dont remember seeing any adapter plugs with the gauge tho... I have the defi racer gauge...heres a website that has some info on them.
http://www.racinglab.com/defi-blue-r...e-df06601.html |
01-09-2009, 03:36 PM | #17 |
Rep 164
you'll most likely need to buy the plug from a third party. all you need to do is find out what thread pitch/size the existing plug is. For subaru's there are things like this...
http://prosportgauges.com/subaru-oil-galley-plug.aspx
01-11-2009, 09:42 AM | #19 |
Rep 405
I posted a basic how to in my earlier post, did you even take a look?
By plug, we are referring to stock oil pressure sensor. You remove that, plug in a male/male fitting, which you connect to a T block. That T block will now have 2 open ports: one to replug your stock sensor back into, and one for your OP gauge. Pretty simple. It is your job to make sure on fitting sizes, adapters (if necessary). I know my Autometer OP gauge in my Mazda came with adapters, so I just bought a Tee and a male/male. |
01-11-2009, 10:34 AM | #20 |
Rep 1,003
thanks pracing, yes i saw the diagram but it was hard to picture. I took a look under the hood yesterday and see exactly what you mean. I just need to go to autozone and find some sort of T/splitter so i can attach both the gauge sensor and the oem one. seems pretty straight forward.
where do u tap into the +,-,dimmer, and ACC? |
