BIMMERPOST Universal Forums General BMW News and Cars Discussion Best Explanation for BMW Break-In Service I've Seen
      09-12-2022, 10:48 AM   #1
HotRodM4
HotRodM4's Avatar
Drives: 2018 M4
2018 BMW M4  [10.00]
BIMMERPOST
     Featured on BIMMERPOST.com
Sounds like BMW uses thin oil for the break-in 1200 mile period for the components to set properly and clean any metal shavings. Essentially get it ready for normal/thicker oil.
?18 M4 Comp
Appreciate 17
///MPhatic15725.00
overcoil3158.50
jmg20646.00
Entropy89206.00
Rocky_M24.00
ppointer1004.50
T0RM3NT4840.50
M3 boi3223.50
Mr.blue255.00
russell21148.50
gnx979.00
2srsman97.50
Niko ZV121.50
      09-12-2022, 11:28 AM   #2
Makes sense.
HotRodM4930.00
      09-13-2022, 06:02 PM   #3
meadowsdb
Drives: '23 M3 Comp X-Drive
Been SOP in the racing world for many years. You run a "break-in oil" that is thinner than the regularone. Drive the car under controlled circumstances and it helps shave down all rough parts, seal gaskets and bearings, and go through multiple heat cycles letting the driveline get all settled in. They you flush it, refill it with the correct weight, and let 'er rip!
Appreciate 15
HotRodM4930.00
AlexFL7991.50
JTO246011.00
///M TOWN33132.50
Tenac4845.00
Mr.blue255.00
FSHNGRY2773.00
alphawawa224.50
2011ninja3463.50
2srsman97.50
agentrnge404.00
TI.3VOM74.50
Thr31.00
      09-13-2022, 09:12 PM   #4
G30M
G30M's Avatar
5655
so apart from change engine oil and rear diff oil,
any other diff oils and other oils to change?
      09-13-2022, 09:20 PM   #5
nioh_lbbm2
nioh_lbbm2's Avatar
1725
Drives: M2
I've been saying this on this forum for years. Break in is needed 100%
nazali1476.50
drjoe66325.50
KoenG1420.00
2011ninja3463.50
Drj161586.00
PABrian149.00
      10-25-2022, 01:03 PM   #6
SpencerC_6MT
SpencerC_6MT's Avatar
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
Anything brand new with spinning metal components will wear down the rough edges under initial use. For that reason, I'd also suggest transmission fluid and transfer case if applicable. Do not flush the transmission fully, just let it drain (for the auto).
2017 BMW M240i 6MT Slicktop | 3.46:1 Wavetrac Diff - MHD Stage 1 - Turner Motorsport SSK - Clutchmasters FX250 Clutch & Steel SMFW - Millway Street Camber Plates - Apex FL-5 18x8.5 - H&R Sport Springs
russell21148.50
      10-25-2022, 01:07 PM   #7
OUGrad05
Drives: 2023 i4 and 2022 Acura MDX
Why do the cars service lights not recommend a change till more like 8-10k miles?
2023 i4 eDrive40
2022 Acura MDX
2021 Cayman GT4
      10-25-2022, 01:08 PM   #8
bcjbmwm3
bcjbmwm3's Avatar
Drives: 2020 BMW M340i xDrive
Anyone had issues getting the service done on their g80. Dealer says that diff fluid is not available and don't have an eta. BMW is saying there is a global shortage.
Current - 2020 G20 M340i Mineral White/Cognac
Past - 2016 F22 M235i Dinan S3, 2009 E92 M3, 2010 Nissan 370Z, 2004 E46 330i, 2003 E46 325i, 1999 E46 323i
lexae6.00
      10-25-2022, 01:09 PM   #9
TurboSid
TurboSid's Avatar
1168
Drives: 2022 M4Cx BSM/FR
2008 335i  [0.00]
My car told me service needed at 1200 miles. started annoying my at like 400 miles.
2022 BSM/FR M4 Competition X-Drive
2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD]
      10-25-2022, 01:35 PM   #10
slalomfever
slalomfever's Avatar
Well made and very informative video!
      10-25-2022, 01:48 PM   #11
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [9.00]
1998 BMW M3  [0.00]
Completed the service on my own dime at 1,200 miles. Fluids are cheap preventative maintenance
      10-25-2022, 01:49 PM   #12
Dgjo2022X5MC
Dgjo2022X5MC's Avatar
Drives: 2022X5MC, 2020 X5 40i
Car will ask for service at 1200 miles when delivered. Not sure why yours wasn't…someone reset the interval?
BMW won't CPO a car that hasn't been run in properly…e.g. near the 1200.
Dont be humble, give me that rumble. 2022 F95 X5MC, 2020 G05 40i, 2016 F86 X6M (sold), 2014 328ix F30 (totaled), 2009 e91 328ix (sold), 1997 740i e38 (nikasil fail)
      10-25-2022, 01:50 PM   #13
OUGrad05
Maybe it's only on M cars?
2023 i4 eDrive40
2022 Acura MDX
2021 Cayman GT4
      10-25-2022, 01:54 PM   #14
Lloydy1980
Lloydy1980's Avatar
Drives: BMW F31
There shouldn't be any rough parts in an M Engine, these are ultra precision made pieces of equipment, the purpose of a running in oil is that it is mineral based with zero additives, it is these additives (found in semi synthetic and fully synthetic oils) that are designed to prevent wear which you don't want in a running in (mineral) oil as this prevents the engine from bedding in properly. If you ran fully synthetic from the get go you'd end up with an engine that won't bed in properly resulting in poor piston ring sealing and increased blow by resulting in oil burn and power losses.
      10-25-2022, 02:07 PM   #15
unfoundnemo
unfoundnemo's Avatar
1963
Drives: 2022 i4 M50
2025 BMW iX  [0.00]
2022 BMW i4 M50  [0.00]
Correct... only M cars that require it.
Not a bad practice to do an extra one anyway if you plan to keep the car long-term.
I had an the oil and diff flushed a second time at 1200 miles in my F92 because they did the break-in service at 300 miles (it was already a year old). I paid out of pocket to have it done because my SA couldn't put it through the maintenance place, but I ended up having BMWNA thanking (reimbursing) me for it.
I would have done it myself in my new m-lite-ish car if I could.
Current: 2022 i4 M50 | 2025 I20 iX
Gone: 2022 G07 X7 | 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC
      10-25-2022, 02:08 PM   #16
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
Agreed. Didn't even try to get them to cover the oil change. I will have two in before they pay for one.
      10-25-2022, 02:15 PM   #17
Edwardsc1
Edwardsc1's Avatar
Drives: 2011 BMW M3 Comp
2011 BMW E92 M3  [0.00]
"Homeboy" got lucky on his engine replacement. Wish BMW hadn't warrantied it for him just because he was such an idiot.
Great information in this video though! Definitely worth the watch past the ~4 minute mark
2011 E92 M3 Comp - Current
2015 X5 50i - Previous
2011 E92 M3 Comp - Previous
2016 F30 340i - Previous
      10-25-2022, 02:17 PM   #18
G30M
G30M's Avatar
5655
ok i'll book it in!
      10-25-2022, 02:24 PM   #19
Brandt51
Flavor of the month
Brandt51's Avatar
1059
Drives: BMW F87 M2C
2020 BMW F87  [9.42]
Another day, another break in procedure thread.
For the record, you are all wrong and my way is the best way. Been doing it for yada yada yada.
Samuel of the Internet
2023 F98 X4M Comp
2023 F95 X5M Comp
2020 F87 M2 Comp
jdubm2c177.50
isenc2155.50
Joebie937.00
G30 B581628.00
ppointer1004.50
      10-25-2022, 03:12 PM   #20
Dgjo2022X5MC
Yes. Only 'full' M require the 1200 run in service. Not sure of M50i. The owners manual will tell you.
      10-25-2022, 03:34 PM   #21
bangerman15
Drives: No bmw yet
Good video.. In the g8x m3/4 Facebook group some of those guys ignore this and rip their cars at around a few hundred mile break in. They were also trolling others for following the recommended break in from BMW M division which, to me, sounds ridiculous not to follow the engineers lol.
PABrian149.00
      10-25-2022, 03:35 PM   #22
Mr.blue
Mr.blue's Avatar
Drives: 2018 M550i Xdrive, 2021 X5M co
Some of the information is obvious but I would say that this is a great informational video. It will hopefully quiet some of the naysayers and nonbelievers that say otherwise. Again, great video.
Mike
