09-19-2022, 10:29 AM | #1 |
Rep 21
Carplay GPS drift
Has anyone noticed a GPS location drift when using Apple Carplay? It has happened at least three times to me that the GPS location is off by hundreds of feet (so completely useless) when using Carplay navigation on 23 X7. It happened to both Apple and Google maps, using my wife's iPhone or mine, before and after iOS 16 update. Reboot of iPhone didn't help but the problem seemed to just go away next time we drove the car (likely due to a reboot of iDrive).
09-19-2022, 10:36 AM | #2 |
Rep 1,657
This would be a phone problem, not an X7 problem, as the GPS module lives in the iPhone, not the BMW.
This happens to me in tunnels and where there are massive over/underpasses, for a few seconds Google Maps thinks I'm not in the tunnel or on the wrong overpass, but then quickly corrects itself. Note that every time Apple releases a new iOS version it takes the map makers a week or two to issue an update to Google, Waze, etc. which normally fixes the black screen problem or the double voice command problem. |
Durham52.00 |
09-19-2022, 11:36 AM | #3 | |
Rep 21
BTW, with Carplay disconnected, both car GPS and iPhone GPS were accurate. |
PinkNinja400Guy515.00 EvanX10.50 |
09-20-2022, 01:56 PM | #4 | |
Rep 82
09-20-2022, 03:17 PM | #5 |
Rep 1,529
I had this exact problem in my S-class.
It ended up being my phone, and problem solved completely when I replaced my iPhone. What is interesting in your case is that both your phone, and your wife's phone are leading to the same issue. What are the chances that both phones have the same issue instead of being an X7 related issue? I don't know. But to be on the safe side, I would at least try another phone that was NOT purchased around same time and same location to your phone and your wife's phone. Also, does the lag happen around the same exact location, or are you seeing the same exact problems regardless of the location? |
09-21-2022, 11:59 AM | #6 | |
Rep 21
09-21-2022, 12:01 PM | #7 | |
Rep 21
09-22-2022, 10:12 AM | #8 |
Rep 1,618
Drives: '23 760ix; '23 X3; '23 MB wgn
IOS 16.1 is supposed to fix "GPS Problems" that were apparently introduced in 16.0.
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler. |
10-22-2022, 10:30 PM | #9 |
Rep 1
This can be easily proven to be a problem with the car and not the phone.
I have a 2023 X7. Connect phone to CarPlay and look at the map. Notice where you are as the incorrect location. Now open the BMW app and look at where the BMW is SELF REPORTING it’s location to BMW. Notice they’re the same spot. So, while the I drive gps is correct for navigation, there appears to be a secondary system generating an incorrect location which is passed on to BMW as well as CarPlay. This is something I’m going to have my dealer look at, i didnt spend all this money on a car that can’t figure out its correct location. |
10-23-2022, 07:24 PM | #10 | |
Rep 398
Most people release the volume knob after the first power off, that's only a soft reset, sometimes that does not fix the issue. The second reboot is a hard reset. |
10-24-2022, 01:35 PM | #11 |
Rep 260
This has happened to me twice. Once on the drive home from the dealership after picking up the car and once today (after about 2 weeks of ownership). What I had to do was force close the google maps on my iphone and reopen it. Not ideal, but solves the problem for now.
10-27-2022, 12:34 PM | #12 |
Rep 11
I had this happen the other day - approaching a destination I suddenly was like 1/4 mile away and on a different road on the GPS than I had been. I wasn't sure what happened and oddly when I put the location in the onboard GPS it worked just fine...
10-27-2022, 08:11 PM | #13 |
Rep 82
I can confirm iOS 16.1 on iPhone 14 Pro Max does not fix the problem. I had it happen again yesterday in CarPlay. GPS on Nav in car seemed fine when I switched over. I’ve restarted iDrive etc. I use CarPlay in a 4Runner and have not had this happen with the same phone. I’m on T-Mobile with personal esim activated in the X7.
10-27-2022, 08:53 PM | #14 |
Rob
39
Rep 85
Mine was working fine until I setup my iPhone 13 as a digital key; then the GPS drift issue began.
Do others having this issue have their phone set as a digital key? |
10-27-2022, 09:32 PM | #15 |
Rep 82
10-27-2022, 09:36 PM | #16 |
Rob
39
Rep 85
And now there is this to throw into the Mixmaster.
https://www.macrumors.com/2022/10/27...ues-for-users/ |
10-30-2022, 04:07 PM | #18 |
Rep 398
Maybe it also has something to do with Waze being overly optimistic with it's arrival and drive time, or did I miss a notice about speed limit being suspended .....
11-02-2022, 09:05 PM | #19 |
Rep 17
I had an issue like this when I first got my 2021 40i -- the car GPS and my phone GPS (Apple Maps, Google Maps, and Waze) intermittently showed my location anywhere between a few hundred feet and several miles from where I actually was. Even the Vehicle Finder in the MyBMW app showed the car's location in random places nowhere near where the car actually was. After several trips to the dealer, it turned out to be the car's GPS antenna and the control unit that supports GPS. Somehow it was affecting my phone's GPS at the same time. They replaced the parts and everything has been working fine since.
11-03-2022, 06:00 AM | #20 | |
Rob
39
Rep 85
robkassab | 2023 X7 40i M-Sport
11-03-2022, 06:34 AM | #21 | |
Rep 260
11-03-2022, 07:12 AM | #22 | |
Rep 17
Here is the completed work order showing they diagnosed and replaced the failed TCB and battery. There was no bulletin that I was aware of, and it took multiple trips to the dealer to get it resolved. (The first time they updated the software and replaced the antenna, which may have been needed but didn't solve the problem.) To prove my point I did show them a Navigation screenshot of my car's location in the middle of the ocean though (see below). Last edited by HatTrick71; 11-03-2022 at 07:21 AM.. |
Slack Beries41.00 |
