09-20-2022, 01:22 PM | #1 |
Rep 152
Overhead Driver's Console Squeaking/Rattling
My new 2022's overhead console that has the front reading lights squeaks and rattles when going over minor bumps in the road. The rest of the car seems pretty solid (although my wife's 2019 CRV still beats any of my past BMW's in that department). I know that this overhead console is the culprit because if I press on it while going over bumps, there is no noise. I suppose I can live with it but if I can fix it, I'd love to give it a shot.
Any suggestions on getting rid of this rattle? I was thinking of pulling it down and lubricating plastic parts that are in contact but hesitant to DIY this if someone else has had an easier fix.
2022 f97 BG X3Mc (current)
2018 f80 BSM M3 CS (gone) 2012 e70 SG X5M (gone) 2012 e92 MW M3, DCT, ZCP (gone) 2009 e92 BS 335i (gone) |
09-20-2022, 02:33 PM | #2 |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
i just bang on it a few times until it goes away.
but don't take my advice.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
09-20-2022, 02:36 PM | #3 |
Rep 3,361
I ended up driving around with a co-worker at lunch and he listed to try and pinpoint my sunroof rattle. He narrowed it down to a loose screw and the washer just bouncing around. Took 7-8 full turns to tighten it down and was likely like that from the factory.
09-20-2022, 03:15 PM | #4 |
Rep 152
Not the sunroof rattle for me as I've read about here on the forum. I've confirmed that it's the plastic from the overhead console where the SOS button is located.
09-20-2022, 04:11 PM | #5 |
Rep 185
I had the same exact thing on my 2021 X4MC. I took it to the dealer, explained the issue and they fixed it. The SA said they took it apart, tightened a few areas and added insulation. Not sure I believe all of that but I can report the mind-numbing creaking/rattling is gone. For now.
clevemont58.00 |
09-20-2022, 07:59 PM | #6 | |
Rep 152
09-21-2022, 09:05 AM | #8 |
Rep 1,495
Same here. Popped it out and popped it back in without really doing anything and it seems to have resolved, at least temporarily. :
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
09-21-2022, 09:46 AM | #10 |
Rep 3,361
Yeah, I was about to lemon law as two attempts by the dealer failed. There are four or eight Torx (iirc) bolts securing the sunroof to the sliding/tilt mechanism...one of the bolts were loose on the front driver's side...such a simple fix and my cabin is quiet!
11-30-2022, 05:07 PM | #12 |
Rep 152
You popped it out yourself? When I took it to the dealer, they said that they get a lot of complaints for the rattle and can look to fix it but no guarantees. They also said that I would have to leave the car overnight and that they would have to take the entire liner and plastic off. I wasn't sure if the SA really knew what he was talking about but I decided to hold off for now.
12-01-2022, 10:05 PM | #13 |
Rep 2
Drives: X3 M40i
Mine did this for a while and then magically stopped. Hope you get so lucky!
12-03-2022, 12:53 PM | #14 | |
Rep 1,495
