09-26-2022, 05:07 PM | #1 |
Rep 220
M Drive Professional with MT and RWD
Most of the information I found on M Drive Professional has either been around drifting or with AWD and automatic transmission. What I'm really curious about how M Drive Professional pairs with RWD models and if the adjustability has any practical application on the street as far as potentially allowing a bit more of the rear to break loose than what MDM provides while still being relatively "safe". Can anyone share their experience with a RWD model and M Drive Professional on the street? I have a deposit down for a M2, so unless BMW really surprises us, xDrive isn't an option.
10-01-2022, 12:11 PM | #2 | |
Rep 4,094
It allow the driver to learn and drive closer to the edge with a level of safety but it also includes a drift analyzer. Its a stage traction/slip control. See the video below https://youtu.be/5QwlgiW5paE https://youtu.be/U3CT13kmNNY |
Jsndiesel325.50 Limegrntaln13707.00 |
10-07-2022, 12:22 PM | #3 | |
Rep 729
Yes it is a great option to have. As I am learning the car in RWD mode I am able to dial in a certain level of protection while still being able to feel what the car is doing. For $1,000 or whatever is costs, it is a one time option — get it now or live without it. On a car of this price point, I wasn’t going to leave that option on the table. There is a great video where someone demonstrates levels 10-0 on a wet skid pad. IIRC somewhere around 5 and under things are pretty loose. EDIT: that second video in the post above is the one I am referring to. Without M Drive Pro you are pretty much on your own in RWD mode. Of course, plenty of a Mustang drivers have demonstrated how well that works out, right?
BMW M3 Competition xDrive, Dravit Grey over Tartufo
Limegrntaln13707.00 904_FireG80308.50 |
10-07-2022, 12:36 PM | #4 |
Rep 140
I have M drive professional on my MT M3. TBH I never really use it. It lets the rear end slip out a bit more than MDM when you set the M Traction Control around 2-3 or so, but honestly I'm not really ever hanging the @ss out in the car on public roads, and in every car I've ever taken on a track / autocross I just turn TC completely off. I don't see the value in it really, but that's just my 2c.
10-07-2022, 01:54 PM | #5 | |
Rep 729
Am I missing something? Can I use MDM in RWD, or not? Perhaps I am doing something wrong. But if I didn’t have M Traction Control ( M Driver Pro) I would have nothing in RWD mode.
BMWRacer5232522.00 |
10-07-2022, 04:26 PM | #6 | |
Rep 2,700
I was disappointed that the stand alone option or M drive Pro was gone for 2023 but after thinking about it it's not that useful since to really use it you have to have your foot planted on the gaz and your not really learning car control that way.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
10-07-2022, 05:19 PM | #7 | |
Rep 729
Are you saying that it is available in the RWD only M3’s?
10-07-2022, 05:30 PM | #8 | |
Rep 2,700
With the AWD car you have AWD, AWD Sport and 2WD and then you also have DSC On, MDM and DSC Off and if I recall correctly MDM is only available in AWD Sport but DSC Off you can be in AWD, AWD Sport or 2WD. You can only use the 10 stage traction control in 2WD and you don't have access to MDM.
10-07-2022, 06:12 PM | #9 | |
Rep 729
2WD is M Pro traction control only. Which is one of the reasons why I say if you get the M3CX that I would definitely get M Driver Pro. Otherwise it seems in 2WD you would not have any traction control options available. 4WD in winter with DSC off will be fun!
10-07-2022, 06:26 PM | #10 | |
Rep 2,700
When experimenting with it on track, I realised it would only engage if I put my foot to the floor during corner exit and didn't seem to help much part throttle so it's kind of usefull to keep your wheel spin under control when fooling around but it encourages you to carelessly floor it. It pains me to say it but it's main purpose is really when your trying to score on the drift analyzer without ending in the bush. An indication of this is in the CSL they reprogrammed the 6-10 stages in a sort of MDM for different environment and track surfaces. I liked to drive in AWD Sport DSC off the most and it's that way I was faster around the track.
10-07-2022, 07:14 PM | #11 | |
Rep 729
Because if so, the Joe Achilles video seems to confirm that it definitely is a stability control system too. It limits and allows levels of oversteer. Granted it might not be the full stability control of DSC or MDM, but I would still consider it stability control.
10-07-2022, 07:44 PM | #12 | |
Rep 2,700
It regulates your oversteer by limiting/allowing power to the rear wheels, very different than a stability control that saves your ass when applying too much steering angle on an off camber turn while lifting the throttle because your scared.
10-12-2022, 08:22 PM | #13 | |
Rep 729
So at 10 there is tremendous understeer because the power is limited and the rear tires are braking, so it just plows into the corner right? This is all very good to know. So M Traction is a different animal than MDM.
10-16-2022, 01:41 PM | #14 |
Rep 1,781
Just to be clear, there is no MDM in an Xdrive model when you switch to RWD only mode. If you have M-Drive Pro option you can set the traction control. I have it and have used it a few times on track but I prefer to drive in 4wd sport mode on track.
10-16-2022, 06:28 PM | #15 | |
Rep 398
so 4wd only works with m drive pro or can use rwd only mode with m drive pro? |
10-16-2022, 08:36 PM | #16 | |
Rep 729
As described above, it will control drift angles with traction control, but is not a stability control system.
PLF693771.50 BMWRacer5232522.00 |
10-24-2022, 10:05 PM | #17 | |
Rep 138
thanks |
10-31-2022, 01:14 PM | #18 |
Rep 1,440
I'm curious what you mean by this. I specced M Drive Professional (1MB) on the 2023 I ordered last weekend. The order guide has it as a standalone option on the Base, Comp, and Comp xDrive variants.
10-31-2022, 02:07 PM | #19 |
Rep 2,700
I think it's still standalone in the USA but only in a package in Canada
