09-28-2022, 04:43 PM | #1 |
Rep 1,559
Downpipe Cell Count
Curious why the Active Autowerke downpipe is frequently recommended as a high flow cat when the cell count is 400, which I believe is inline with the cell count in the OEM downpipe? If so, is there really that much difference in flow? Is this also why AA can pretty much guarantee it won't throw a CEL?
UPDATE: OEM cell count = 700 Last edited by XC3LLR8; 09-29-2022 at 11:00 AM.. |
09-28-2022, 05:41 PM | #2 |
Rep 611
Stock cell counts are usually around 800 if not higher.
I attached comparison photo of my aa to stock. It’s a good difference. I love the aa downpipe. Zero cel, great sound, no smell, and noticeable power increase by itself. It’s zero cel not just because of cell count but because of the amount of precious metals that make up the cat. Cheapo catted downpipes aren’t going to have even close to the amount of precious metal which will contribute to a cel. Last edited by Rdurty2; 09-28-2022 at 05:46 PM.. |
09-28-2022, 06:03 PM | #3 | |
Rep 1,559
Alpine Flyer138.00 |
09-29-2022, 05:12 AM | #4 |
Rep 611
It’s pretty easy. I did it on jack stands.
If someone would consider installing an intake a 1 then I think the downpipe install would be a 2/5 |
09-29-2022, 10:46 AM | #5 |
Rep 1,559
I called Fabspeed to inquire about their downpipe as they use a 200 cell. However, they did not list the G42, but they were curious if the downpipe for the M340i was the same. I called my BMW dealership and confirmed the downpipe part numbers for a G42 M240i and a 2022 M340i are the same.
Now it looks like the two top-tier downpipes - Fabspeed and Active Autowerke - are the ones I'd like to compare. OEM = 700 cell Active Autowerke = 400 cell / $1,500 Fabspeed = 200 cell / $1,996 Both guarantee no CEL. "This downpipe feature German made HJS 200 cell EURO 6 compliant trimetallic catalytic converters. We use 4 in piping from the engine side to the cat, and 3 in tubing from the cat to the rest of the exhaust. Our larger catalytic converters are better because they allow for more exhaust flow and the increased catalysts surface area allows for better exhaust gas filtering which means emissions compliance that will NOT trigger a check engine light. Our Sport Cat Downpipe are a direct bolt-on replacement for the factory M340i catalytic converter.I'm a little concerned I'd be overpaying for the Fabspeed name, as they're selling a $70 K&N drop-in air filter (labeled BMC F1) for $200. LOL |
09-29-2022, 01:36 PM | #6 |
Rep 611
Honestly there will be next to no difference between them. High flow cats are so efficient now that you are probably talking single digit 1-5 HP differences, if any difference at all. Nothing you would ever feel. Even the difference between high flow cats and catless is very minimal these days.
I see that fabspeed uses interlocking bellows for their flex section. I know that on other makes interlocking bellow flex sections can create some noise. |
09-29-2022, 01:39 PM | #7 | |
Rep 1,559
Sonic RR127.50 |
09-29-2022, 05:04 PM | #9 | ||
Rep 116
XC3LLR82062.50 |
09-30-2022, 07:17 AM | #10 |
Joint Chiefs of Staff
24342
Rep 191,129
The CEL count is not necessarily linked to the no-check engine light. The quality of the cats is the most significant factor.
Active Autowerke uses high-quality GESI cats (EPA Approved); they are the most popular because Active Autowerke will replace your downpipe for free if you get the CEL. HJS cats are 300 CEL, also no check engine light. You will get a check engine light if you get a lower quality 400 CEL or 300 CEL downpipe. The same goes with the flow; a high-quality 300 CEL will flow better than a low-quality 200 CEL.
12-09-2022, 11:42 PM | #12 |
CE560XL Pilot
53
Rep 91
12-10-2022, 04:06 AM | #13 | |
Rep 611
This is the one you buy: https://x-ph.com/active-autowerke-aa-bmw-supra-b58-catted-downpipe-fits-f-g-chassis-supra/ |
12-10-2022, 09:34 AM | #14 | ||
24342
Rep 191,129
HawksG4253.00 |
12-15-2022, 07:07 AM | #15 |
Rep 87
12-15-2022, 08:34 AM | #16 |
24342
Rep 191,129
Check your inbox
12-15-2022, 12:36 PM | #17 |
Rep 14
someone use the Miltek catted downpipe ?
They don't specify anything about the cel on their site, I've already ordered the full catback, but I hesitate for the catted DP, it's about $400 (Canadian) cheaper than the Active. I tend to tell myself that Miltek is a reputable company and that they make quality products. What do you think ? |
12-16-2022, 09:01 AM | #19 |
24342
Rep 191,129
12-16-2022, 01:22 PM | #22 |
24342
Rep 191,129
