2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack PA4 Staggered alternative to 245/35R18
      10-04-2022, 12:39 PM   #1
VAcurler
Drives: 21 F23 M240i MT + 09 e90 328i
I have the factory staggered 18 inch wheels and after driving in snow once on 17 inch all-seasons last winter have decided that I want to put winter tires on my OEM wheels (and then buy new wheels for the summer). Since I expect to see snow less than 1x/month I am going to buy the Alpin PA4. However as most know the PA4 does not come in a 245/35R18.
Since 99% of my driving is simply cold (30 to 60 degrees) I want to keep the staggered setup and not go square.
Is anyone running a different size than factory on 18s in a PA4 or am I stuck between running square PA4 or switching to the Pirelli Sottozero at $600+ a tire?
      10-05-2022, 11:20 PM   #2
Kernel Kurtz
Kernel Kurtz's Avatar
347
Drives: 2020 M240i xDrive
Lots of choice in 245/40R18. If you must do staggered maybe do 225/45 in the front and 245/40 in the back? They should fit no problem on factory wheels. Will throw your speedo out by a bit.
      10-06-2022, 07:50 AM   #3
Heitzer
Drives: M235i; BMW S1000RR
I have run the PA4s in 245/40 in the rear for several winters. Fronts are 225/40. I had no problems and like how the tire feels for daily driving. Wear and increased noise after 15k or 2 seasons are the major downsides.
The 245/40 was on the OEM 8 inch for a while. I moved to an 8.5 wheel later to help with increased wear in the center of the tire. That set up also works fine.
[FONT="Arial"] M235i 6 speed, MGM. Wavetrac LSD with altered final drive ratio, MPE, MPK Airbox, side skirts, diffuser, Dinan springs, LCAs.
      10-06-2022, 12:20 PM   #4
Kernel Kurtz
347
Yes, looks like the OPs car is a manual and thus RWD, so 40s at both ends should work fine too.
Heitzer103.00
      10-07-2022, 10:06 AM   #5
VAcurler
Yes RWD 6MT.
https://www.michelinman.com/auto/tir...a4?tyreSize=18
Shows a
225/40 and 235/40
225/45 and 245/45
but no 245/40 in the PA4.
      10-07-2022, 11:51 AM   #6
Heitzer
Interesting! Michelin may have discontinued that size. Two 245/40 options are available at Tirerack.
VAcurler116.00
      10-07-2022, 02:48 PM   #7
Kernel Kurtz
347
Costco (here in Canada) lists them online as well, but they show as out of stock.
      11-15-2022, 11:12 AM   #8
lasiter
Drives: BMW 228i
I have a 2014 228i with 18" wheels, can I put 245/35/18 tires on all 4 wheels without any problems?
      11-15-2022, 05:59 PM   #9
Kernel Kurtz
347
No.
2addicts
