10-05-2022, 02:47 PM | #1 |
Rep 153
LCI M Performance Steering Wheel Trim
I’m looking for the the Carbon/leather M Performance Steering wheel for a LCI car, I’ve found one part number which if for DAP equipped vehicles, none DAP don’t appear to be listed.
DAP equipped 32302471439 I’ve found a part number for none DAP but it doesn’t say it’s for the LCI, 32302459671 it looks identical the the LCI DAP version albeit it dosen’t have the notches above the buttons. Airbag, steering wheel pre LCI and LCI carry the same part numbers, buttons look the same so in theory it should fit, anyone with a none DAP LCI tried it? 2020 pre LCI steering wheel Pre LCI trim https://www.schmiedmann.com/en/produ...2-30-2-459-671 LCI trim (DAP) https://www.schmiedmann.com/es/produ...2-30-2-471-439 Looking at the two above the fixings look identical |
10-05-2022, 06:39 PM | #2 |
Rep 126
Hi,
I purchased the same one and installed it. I don't know why BMW doesn't offer this option on our cars...anyway, here below is a link. You got the right product number. https://www.bmwpartspros.com/oem-par...im-32302471439 |
10-05-2022, 08:32 PM | #3 | |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
32302459671 is the correct part number for heated steering wheel without DAP for LCI cars.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
JonD99995.00 |
10-06-2022, 01:51 AM | #4 |
Rep 913
Drives: 2022 X3 M40i LCI
Is this the trim your after?
2022 X3 M40i LCI. Brooklyn Grey Metallic. Driving Assistant Professional. Black with Blue Stitching Vernasca Leather M Seats. Comfort Pack. Pano Roof. OEM Carbon Fibre Interior Trim. 21” 718 Alloys.
10-06-2022, 01:59 AM | #6 | |
Rep 153
10-06-2022, 02:45 AM | #7 |
Rep 913
If you want to be absolutely sure you’re ordering the correct part for your car, go to your local main dealer parts counter. They will search for parts on the cars chassis number and their system will only suggest parts for your car. Ask them to search for wheel trims and get the correct part number that way. That’s what I did. I then looked the part up online there and then and showed the parts guy the cheaper prices online and he did me a deal. That way you know your getting the right part for your particular car.
10-06-2022, 03:04 AM | #8 | |
Rep 153
They won’t let me order it on the basis that if it doesn’t fit they accept the return. |
10-06-2022, 06:12 AM | #9 | |
Rep 913
I would think if you order through the main dealer using your chassis number then it’s on them if they supply a part that doesn’t fit. If the system is showing that part number for your car then I would suggest it is the correct part.
10-08-2022, 01:55 PM | #11 |
Rep 153
Thanks, yes picked on that need to make sure it’s 2020+, 32302459671 seems to be the right number, just awaiting on the price from my dealer, regards they won’t accept a return so it’s at my risk.
10-08-2022, 01:58 PM | #12 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3563
Rep 4,248
10-09-2022, 04:22 AM | #14 |
Rep 334
Hi JD, I was somewhat struggling on this one too, there are non DAP M Performance Parts Carbon trim available for this (w/o notches) , but I did not like the finer carbon fibre weave, it did not match the CF on the dash which is coarser. What appears to work, and needs verifying with BMW is the non DAP , with Heated Steering Wheel button, for the new G80 / G82 M3 & M4s, also has the coarser cf weave, this also matches the weave on the G80 / G82 CF paddles
Fitment should be identical, a straight swap
Gone: 2020 F82 M4 Comp Ultimate - Austin Yellow Metallic
Gone: 2017 i8 Coupe - Crystal White / BMW i Blue Accent Gone: 2021 X3MC LCI - Marina Bay Blue Metallic Gone: 2018 F32 440i MSport+ - Alpine White Gone: 2018 F87 M2 - Alpine White Last edited by HoJoRo; 10-09-2022 at 04:57 AM.. |
JonD99995.00 |
10-09-2022, 09:35 AM | #15 | |
Rep 153
Edit: From what I can see the G80/2 are different, they appear to be a two piece item, also fixing points at the rear appear different. https://www.bimmerworld.com/Safety-R...309882893.html Last edited by JonD999; 10-09-2022 at 09:54 AM.. |
HoJoRo315.50 |
10-10-2022, 08:09 AM | #16 |
Rep 4,401
1. I don't know why this thread is still on going. there is NO difference between the MY21' pre-lci and the lci steering without DAP... the original part number "32302459671" is the correct part number. this part is also shared with the 5er, X5, 8er, etc.
2. the G8x trim will NOT fit at all. the steering wheels are different.
10-10-2022, 09:04 AM | #17 | |
Rep 1,716
Drives: 22 X3MC MBB - C-17 Globemaster
10-10-2022, 09:55 AM | #18 | |
Rep 4,401
so what you're saying is that hypothetically, with coding, I can enable DAP "Assist Plus" on highway speeds above 40mph without ever having to touch the steering wheel? and this wouldn't effect any other assist features (like Parking Assist or Reverse backup)? I'm assuming more advanced coding is needed and it can't be done via bimmercode or something? because THIS idiot wants to experience some idiot things... as long as its reversible too.
10-10-2022, 01:17 PM | #19 | |
Rep 1,716
:cough: :cough: |
10-10-2022, 01:28 PM | #20 | |
Rep 4,401
