10-08-2022, 12:22 PM | #1 |
BMWnation
425
Rep 514
Engine fault code (1C0001) keep coming up?
Hi all, have no check engine light, but I decided to check codes with MHD app and noticed this code:
1C0001 - Oil-pressure control: Pressure variations. This is the second time it has came up. Car works fine. Anyone have any insights what the issue is? Thanks |
10-09-2022, 11:09 AM | #2 |
Rep 1,512
If I had to guess, oil pressure sensor or worse case an oil pump…
2022-G80 Xdrive BG
2014-GTR BE FBO 2016-HURACAN 610-4 (SOLD) 2021-G82 BASE (SOLD) |
01-02-2023, 11:44 AM | #3 | |
Rep 373
I had the same issue, It was a recall with my car with main bearing shell. I got a full motor replacement and took about 3 months at a dealership.
2010 E90 M3 ESS-vt1 550 SOLD but never forgotten
2015 F80 M3: JB4 and MPE 2022 G80 M3CX: At port |
vitipr171.00 |
03-05-2023, 09:28 AM | #4 |
BMWnation
425
Rep 514
Thanks for the information. Good to know. The code came back up again after a long time. Will have the dealer look into it. Looks like there is a possibility folks might be getting this code but unaware as it does not throw a check engine light. You have to ready your DME to get the codes |
03-05-2023, 09:32 AM | #5 |
BMWnation
425
Rep 514
10-04-2023, 04:32 PM | #7 | |
Rep 884
2022 G80 M3 6MT
2020 G20 330i xDrive 2011 E90 335i xDrive 1996 E36 318i |
Tgrossi941.50 |
10-11-2023, 03:10 PM | #8 |
Rep 884
update: one of the members told me this was related to moving the car while the engine was off. after he stopped doing that the code went away
i suspect that this is my case as well, as I am manual I often roll my car out of the garage down the driveway without turning on the ignition. I cleared the code and stopped rolling my car, and am now reading my codes once a week so far it hasn't popped up again
2022 G80 M3 6MT
10-11-2023, 06:31 PM | #9 |
xdrive
57
Rep 62
In my case it was a bad oil pressure sensor... At 1800 miles.
GrannyShiftG801309.50 |
11-11-2023, 06:53 AM | #11 | |
Rep 260
11-11-2023, 01:50 PM | #12 |
Rep 884
no, mainly for washing my car in the driveway without needing to wake up the whole neighborhood
2022 G80 M3 6MT
11-20-2023, 08:28 AM | #13 |
Rep 884
Dealer diagnosed failing engine oil pump
Back ordered part for 3 weeks and then entire engine will need to be pulled apart 20 hour job
2022 G80 M3 6MT
11-23-2023, 01:39 PM | #14 |
Rep 1,512
11-23-2023, 01:41 PM | #15 |
Rep 884
Bmw said no
2022 G80 M3 6MT
