10-11-2022, 10:49 AM | #1 |
Rep 271
Camber Plates
Does anyone make front camber plates for the G42?
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
11-08-2022, 10:15 AM | #3 |
Rep 271
I have installed the Vorshlag camber plates and worked out very well. The max neg. camber is approx. -3 degrees. If anyone does this it is highly advised to replace all suspension bolts removed since they are torque to yield bolts.
12-08-2022, 07:52 AM | #5 |
Rep 271
With these camber plates I can get about -2.5 to -3 degrees camber and I would set toe at 0 or just a bit positive toe for track set up. This is what I run on the track for street -.5 camber and 0 toe or a bit negative toe. These camber plates are very easy to adjust. For adjusting toe I use Longacres toe plates and adjust each tie rod equally. I have read other toe plates use very thin metal and bend easy so I stayed away from them.
kkgriss9.50 |
12-09-2022, 03:45 PM | #6 | |
Rep 18
