10-14-2022, 11:06 AM | #1 |
Rep 66
Leveling button INOP
All of a sudden the height setting button on my center console is not working. No lights nothing. Have Appt with service next week. Anyone else run into this.
By the way this is a 2022 |
10-14-2022, 12:15 PM | #2 | |
Rep 200
If still not responding, hipefully it is a fuse. |
10-14-2022, 12:29 PM | #3 |
Rep 1,529
To get the air suspension back to work (re-enable it), make sure the ignition on (engine has to be off), push up or down on the switch for exactly 7 seconds (exactly 7 seconds, no more or less). Try first the 7-secounds with the switch pushed down. If it doesn't work, exit the vehicle, lock, unlock, turn ignition on, and try again while pushing up instead. That should re-enable the system if that is what I think it is. You will see the green dash line back and then u know it is working now. If this does not work, you might have a faulty module - take it to the dealer.
