10-22-2022, 11:32 AM | #1 |
Rep 270
Supra strut bar - yes or no?
https://www.evasivemotorsports.com/s...upra-a90-2020/
Would something like that fit the G42? I'm under the assumption that the two side strut braces fit either car but is the distance between the two strut towers the same? |
01-16-2023, 09:03 PM | #2 |
Enthusiast
292
Rep 287
Drives: 2022 230i M Sport
I like it, but no way, IMO, that main bar or those brackets fit under the hood.
02-04-2023, 09:52 AM | #3 |
Rep 147
Drives: 2022 M240iX
Dinan offers a strut bar for the G42:
https://www.dinancars.com/products/s...arts/D180-0014 It does not go across the towers so some have questioned the effectiveness of this sort of strut brace.
BMW #9: 2022 M240ix (Dec 2021) BMW #8: 2022 330iX (Dec 2021) Past: 320iX, M550iX, M235iX, 335iX, two Z4, 540i |
04-14-2023, 01:41 PM | #4 |
Rep 59
I bought G22 OEM parts to install it in a OEM+ modification style.
There are several posts in g20 forum https://g20.bimmerpost.com/forums/sh....php?t=1810482 For sure it's one of the cheapest options, both strut bar, the front bar (the g20 and g42's one doesn't have threads for bolts) and all the bolts cost me about 200$ (180€). |
04-17-2023, 03:24 PM | #5 | |
Rep 147
Drives: 2022 M240iX
BMW #9: 2022 M240ix (Dec 2021) BMW #8: 2022 330iX (Dec 2021) Past: 320iX, M550iX, M235iX, 335iX, two Z4, 540i Last edited by dszpiro; 04-17-2023 at 04:24 PM.. |
SpecTaqlar7.50 |
05-18-2023, 08:41 AM | #7 |
Rep 147
Drives: 2022 M240iX
Looks good! When you say "OEM ones", do you mean these are BMW parts? If so, do you have the part number?
Thanks!
Nate48150.00 |
05-19-2023, 04:49 PM | #8 | |
Rep 59
they are G22 OEM parts, part numbers are: Strut : 51617456115 x2 stock are bare metal, you can paint it if you want Bolts : 51716966566 x4 The front brace don't have the nut so you need to change also the front brace to the G22 one ( p/n: 51648491817 + required bolts 07147270121 x4 ) or use a rivnut o just a nylon nut to install it. Also you will need to tap the strut hole (M10x1.5) Replacing the front bar the hardware is less than 200$ and installation it's pretty straight forward. |
09-19-2023, 09:34 PM | #9 | |
Rep 375
Did that include swapping the front bar with the threaded holes?
10-02-2023, 02:03 PM | #10 | |
Rep 16
dszpiro53.50 |
12-21-2023, 02:14 AM | #12 |
Rep 4,526
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
SpecTaqlar7.50 |
04-22-2024, 04:41 PM | #14 |
Rep 1
OEM Strut Bars
Cheers,
New to the BMW world but not to car modding, happy to have a turbo back under the hood. It all started with a 95 Eclipse GSX, then a G35, now this! My first bolt-on while I wait for Dinan intake parts to show up was the OEM Strut bars. BMW (51-61-7-456-115) x2 I used stainless rivet nuts for the front (M10 Stainless Steel Rivet nuts M10-1.5mm Threads) and beveled a lip if I need to remove that aluminum plate, then tap’d the rear holes Metric Thread Tap,M10 Right Hand Thread Tap (M10x1.5) M10 Stainless Bolts and washers The entire process took maybe an hour, going slowly – It was pretty easy. I polished the bars for bling. I purchased the bars from getbmwparts.com Love this car, still 600 miles into break in - Maybe this info will help anyone interested. Great Forum! |
05-07-2024, 11:04 AM | #15 | |
Rep 1,878
05-07-2024, 11:48 AM | #16 | |
Rep 1,878
05-07-2024, 01:01 PM | #17 |
Rep 2,095
Shame it doesn’t seem to be available in the UK.
I’d have that in a heartbeat! Edit: just emailed them and they do ship to the Uk! Last edited by Pentland; 05-07-2024 at 01:07 PM.. |
