10-22-2022, 10:06 PM | #1 |
Rep 661
US market - upgrade to laser light questions
I searched for answers but really didn't find related to my questions regarding the laser lights.
I mainly care about the low beam output and coverage, don't really care for the anti-glaring or if the low beam is LED/Laser. 1. For LOW beam, is there any difference between standard LED and upgraded laser lights? My understanding is the laser lights is only for high beam and as the DOT approval just passing, it's still not enabled and no timeline on it. Read this but doesn't seem to answer my question https://www.bmwakron.com/blogs/1468/...ealer-near-me/ 2. Is there any special animation with the laser lights when you unlock or turn on the lights? 3. Is the $1k option worth getting if in the US? I'm quite happy with the standard LED lights on our 45e but I heard from forum members iX standard LED lights aren't that bright and have yellow hue.
Future mod consideration: exhaust, pulley
otherwise, very happy with how the m3 was born |
10-22-2022, 10:43 PM | #2 |
Rep 661
Never mind on the #1, found the answer
https://bmwi.bimmerpost.com/forums/s...2&postcount=55 Laser is only for the high beams, no difference on low beam whether you upgrade to laser lights or not.
10-23-2022, 02:02 AM | #3 |
Rep 157
i am actually interested myself in retrofitting my current led lights to laser lights when theyre available as i noticed the led lights do have a faint yellow hue when turned on at night. came from a 45e with laser lights and those were really clear(whiteish)/bright than on the iX, pretty disappointed
in this video you can see that there is blue line that lights up for the laserlight option |
TXSTYLE13996.50 |
10-23-2022, 02:27 PM | #4 | |
Rep 661
I guess I'll add the laser lights to the build.
10-24-2022, 12:15 PM | #5 | |
Rep 1,833
Drives: BMW iX Xdrive40 MSport
On the retrofit topic you’re out of luck. It’s been discussed in a couple of forums now that the IX is not at all coding friendly. 97% of the module coding files are stored in the cloud and only accessible by BMW authorised connections and the files that are available are trimmed which require decoding. Since only the MGU, RAM and CCU module files are available offline the coding options available are very limited. Unless a BMW dealer is willing and able to perform the retrofit you’re going to be stuck with the LED lights. |
10-24-2022, 01:58 PM | #6 |
Rep 31
Very interesting hugo_nz ! I always thought that another difference between LED and Laser was that Laser lights are "adaptive", meaning that they're able to rotate left/right when turning. But from what you're saying, that wouldn't be the case? Unless LED lights can rotate as well, which I doubt?
10-24-2022, 02:31 PM | #7 | |
Rep 157
10-24-2022, 03:40 PM | #8 | |
Rep 1,833
The laser quipped head lights also add a dedicated cornering lamp for tight corners.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
10-25-2022, 08:27 PM | #9 |
Rep 31
My xDrive50 arrived today at the dealership so I dropped by to see it. Got to discuss with a sales rep who said that the retrofit would probably be $6,000 to $7,000, so "not worth it", to which I agree
