10-24-2022, 04:50 PM | #1 |
Rep 751
JB4 v JB+
I'm just about to take delivery of my M240i Xdrive
If I'm not planning any bolt ons is there any advantage in getting the Jb4 over the Jb+ performance wise? I'm not interested in logs or obsessing over AFR's. I just want a simple plug in and forget. If I fitted the JB4 I would only use map 1 (3 psi) or map 2 (4psi). I'm just planning a K&N panel filter an running a JB+ in the standard 3 o'clock position which is probably = 4 psi. My question is, will map 2 Jb4 have any advantages over JB+ 3 o'clock position In terms of power delivery? |
10-24-2022, 05:36 PM | #2 |
Rep 1,559
Based on a recent YouTube video I watched the guy had a side-by-side screenshot of a pull to about 130 mph with the JB+ and JB4 in a newer B58 BMW. They were almost identical with the settings you described.
FWIW, I have a K&N drop-in and JB+ and run the car 90% of the time in Sport Individual. I'm so addicted to its performance and for the first time in my life I crave getting red lights. However, I'm sure in about a year I'll be ready for a little more and plan to get the AA catted DP and take advantage of the 100% trade-in on the JB+ for the JB4. |
10-25-2022, 09:03 AM | #3 | |
Rep 751
Just wanted to check if I was missing anything in my decision. Seems if you don't plan on running bolt ons or anything above map 2 and have no desire to run data logs then it seems the JB+ is the right option. |
10-25-2022, 09:26 AM | #4 |
Rep 1,559
At least for the new M240i, I can't imagine anyone not falling in love with the JB+ on a stock car, especially for the price!
Alpine Flyer138.00 |
10-25-2022, 10:57 AM | #6 | |
Rep 1,559
Nearly 40 HP/TQ for $240, 2-3 minute install, and 100% credit towards a JB4 within a year. In Sport and Sport Plus I really believe the car is smoother than factory. |
10-25-2022, 10:58 AM | #7 | ||
Rep 751
Is it night & day compared to stock? |
10-25-2022, 11:18 AM | #8 | |
Rep 1,559
Night & day? No. I would consider night & day going from stock to DP, tune and E85. Is the JB+ obvious you did something? Definitely! I'm knocking on my wood desk as I type this... but so far it's a no-brainer! |
10-25-2022, 12:42 PM | #9 | |
Rep 117
10-25-2022, 12:44 PM | #10 |
Joint Chiefs of Staff
24342
Rep 191,109
The new models run high boost from stock; in optimal conditions, the stock is running 20 PSI. Adding 3-4 PSI on top of that without the ability to datalog is not a good idea, in my opinion
I recommend you get the Jb4 and use their absolute map, which limits your PSI to keep it safe in all conditions.
Alpine Flyer138.00 idontsave370.50 |
10-25-2022, 12:51 PM | #11 | |
Rep 1,559
If I were to do an intake it would likely be the Eventuri. Way overpriced, and mostly a sound mod, but I've heard great things about the sounds it makes... https://www.eventuri.net/products/bmw-g42-m240i-b58/ |
10-25-2022, 01:07 PM | #12 | |
Rep 1,559
I've done a few datalogs (before buying the JB+) with the OBDLink CX and I cannot recall ever seeing 20 psi. You got me curious so I just went through several datalogs and the highest boost I could find was 16.68 psi. |
Alpine Flyer138.00 Redbeemer88.00 |
10-25-2022, 01:15 PM | #13 | |
Rep 751
Is this a set custom map or does it adapt to certain parameters? |
10-25-2022, 01:20 PM | #14 |
Rep 117
10-25-2022, 01:34 PM | #15 | |
Rep 1,559
10-25-2022, 01:47 PM | #16 | ||
24342
Rep 191,109
This is not over boosting as over boosting is when the car is hitting a target higher than the set target by the ECU. In this case, the ECU is setting boost at 20 PSI and the car is hitting 20 PSI Quote:
Map0: Stock tuning, fully disable JB4 Map1: Additive map with peak of 3psi over stock added (91 octane) Map2: Additive map with peak of 4psi over stock added (91-93 octane) Map3: Additive map with peak of 6psi over stock added (93+ octane) Map4: Absolute target map with peak of 20psi target (93+ and/or E30 octane) suggested for higher boost models like G chassis, Supra, and Z4. EWG required for proper control. Map5: Absolute target map with peak of 22psi target (E30+ fuel) suggested for higher boost models like G chassis, Supra, and Z4. EWG required for proper control. Map6: Custom tuning map allowing both additive (below 10psi) and absolute (above 10psi) targeting. Setting RPM1500 boost below 5.7psi will make entire map6 additive, setting above 6psi will make entire map6 absolute target. Map7: WMI map (boost varies based on WMI additive, meth flow, and other criteria) Map8: VALET / Low Boost Map Map 1/2/3 adds a set amount of boost to the Stock PSI. That's how every piggyback works. These are called additive maps. Map 4/5/: set a target limit regardless of the PSI boost. this is a Jb4-only feature that other piggyback can't offer. It's called absolute maps. Absolute maps are the best maps to run on high-boost stock applications like this car, especially when paired with low-quality gas (91 or 93).
XC3LLR82062.50 Summeristooshort16.50 |
10-25-2022, 03:15 PM | #17 | |
Ne Plus Ultra
88
Rep 264
Drives: Portimao Blue 2022 M240iXdrive
Alpine Flyer138.00 XC3LLR82062.50 |
10-25-2022, 03:43 PM | #19 | |
Rep 1,559
BTW, is the boost in this log the TRUE boost, or the boost the ECU thinks it's sending which does not include the additional 3.5 - 4 psi the JB+ is adding? The first table is sorted by boost: high to low The second table is unsorted and a reference of the data before and after max boost. Last edited by XC3LLR8; 10-25-2022 at 03:49 PM.. |
10-25-2022, 03:45 PM | #20 | |
Rep 1,559
Redbeemer88.00 |
10-25-2022, 04:46 PM | #21 |
Ne Plus Ultra
88
Rep 264
JB+
You didn't state how much of a gain your butt dyno felt from the tune. Did it pull smoothly and drive smoothly in normal, part-throttle, driving. Did you record any 0 - 60 or other times?
Thanks! |
10-25-2022, 05:11 PM | #22 | |
Rep 1,559
The one time I did a proper launch-control pull my wife was with me and nearly vomited in the car. I've had PTSD since then. |
Redbeemer88.00 |
