10-24-2022, 06:40 PM | #1 |
Rep 17
2023 x4 m40i aftermarket wheels
Pretty inexperienced with wheels sizing. Would greatly appreciate a little peace of mind on purchasing after market wheels.
struggling with what is acceptable aftermarket wheel sizes for a 2023 X4 M40i. My new X4 is just starting production now. It is coming with 20" performance nonRFTs. I plan on putting on separate 19" winter tires/wheels on pickup. BMW offers 1 winter wheel/tire package with pretty lackluster rims. OEM 19" are 7.5x19, offset 32 (to the best of my knowledge) Tire rack lists rim widths 7.5-9.5 as options. Offset 25-38 as options. I'm scared to buy just anything listed in these wide ranges. Tire rack rep says all are acceptable for the vehicle. As the rim width goes up, should the offset go up or down in relation to stay towards OEM type ratio?? Would greatly appreciate any guidance. I'm less concerned with aesthetics and most concerned with potential mechanical issues that could occur from improper sizing. Thank you for any help on the subject! |
10-25-2022, 12:30 PM | #4 |
Rep 3,361
Since you did not ask for alternate wheel and tire dealers, I'll attempt to answer you;
As the rim width goes up, the offset should go up to keep the face of the wheel from moving it's position vs the fender. A general rule of thumb would be that for every 0.5" of additional width you would add 5mm of offset to retain the factory "poke". That said, if you go too wide, you can run into strut/spring clearance issues. Here is a good website where you can play with different wheel and tire sizes: https://www.willtheyfit.com/ Before deciding to go with a 19" wheel, look at tire selection availability. 20" is certainly a more popular size vs. 19" in terms of available tire combos. If you truly don't care about aesthetics, stick with a 7.5" width wheel, 30-35 offset and the narrowest winter tire you are comfortable with, in a square set-up. |
10-25-2022, 01:48 PM | #5 | |
Captain (Retired)
4061
Rep 1,792
My primary concern was ensuring the correct offset tbh; had largely settled on all other variables Last edited by Rottweiler; 10-25-2022 at 02:09 PM.. |
dmanb2b2134.00 |
10-25-2022, 02:11 PM | #6 |
Rep 3,361
I understand. I could have worded my reply slightly differently. Ultimately, just trying to share my knowledge as I have pieced together a few sets over the years and OP seemed interested in learning more.
Rottweiler4061.00 |
10-28-2022, 10:47 AM | #7 |
Rep 17
Busy week. Haven't called yet. Curiously, their website showed no hits for wheels for my vehicle in their built in search.
10-28-2022, 02:09 PM | #8 | |
Rep 17
