Help, my e91 is throwing tons of codes
11-02-2022, 06:36 PM | #1 |
Rep 8
My e91 (n51 with 84,500 miles paired with the 6l45 automatic) has had some issues lately, nothing that I can't take care of or that confused me; I've replaced the alternator, starter, and battery.
More recently after I replaced the starter 2 days ago the car was running fine and well. I took it for a drive around my neighborhood with a new air intake in as well. I drove back home and turned the car off and then 30 minutes later I decided to go to the autoparts store. Right as I left my neighborhood I my engine suddenly started ticking loudly, I then pulled over in the closest neighborhood I could find and replaced the new intake with the stock air box after I noticed the MAF sensor sitting unevenly in the new intake. I then drove it back home and parked it until today. Did some research and thought it might have just been lifter tick. Today I drove it to the autoparts store and used their code reader and got hit with a whopping 16 different codes; here are 15 of the codes: 2A77 - ECU internal error: Valvetronic-output 2A3F - Valvetronic servo motor: power supply CDAD - Message (requirement road wheel torque drive line, BF) CD99 - Message (torque requirement EGSelectronic gear control?, B5) CDA1 - Message (steering wheel angle, C4) CD9E - Message (gear data 2, 1A2) CD98 - Message (Torque Requirement DSCdynamic Stability Control, B6) CD9D - Message (Gear Data, BA) CD9C - Message (Speed, 140) CDA5 - Message (Status DSCdynamic Stability Control, 19E) (code 11 which is the only one i don't have a picture of; it is just another message code) CDB0 - Message (Display Gearbox Data, (1D2) 29CE - Misfirings, cylinder 2 2D67 - DME Digital Motor Electronics, Internal Failure: Control Processors 578E - Transmission fluid deteriorated CF1C - Lost Communication With DME I have owned this car for the past 4, possibly 5 months and have treated it very well; I have replaced the aforementioned starter, alternator, and battery, along with wheels, tires, coilovers, oil, oil filter, and headlights. If someone could possibly help diagnose what is going on with my car then I would be forever grateful. So far my only guessed are the ECM or the Valvetronic motor but I could be completely wrong. |
11-02-2022, 06:45 PM | #2 |
Rep 1,309
Step one I would get something that'll let you read codes with your phone... I use the protools app with a kdcan USB cable and a cheapo USB OTG cable.
This will let you read the codes and see if they are current or historical. The loud ticking coupled with the valve tronic motor error... This would make me want to run through the diagnosis procedure for the valvetronic motor to make sure it's not hosed. |
11-02-2022, 07:43 PM | #3 | |
Rep 4,108
1) What are Last-7 Characters of VIN? What is Build Mo/Yr. of your E91/N51? 2) Why was Alternator replaced & WHEN? 3) What make/model/Part# alternator was installed as replacement? New or Reman? 4) Do you have a Multimeter? 5) What Warning Lights appeared PRIOR to replacing Alternator? 6) What Warning Lights appeared on Instrument Cluster BEFORE codes read? 7) Do you have a Windows OS Laptop? 8) Do you have an Android Device? 9) What CC-ID Codes do you have? Follow "Check Control" Procedure in Owner's Manual to read CC-ID Codes. 10) WHERE is ticking noise coming from? Use $5 (HFT) Mechanic's Stethoscope or HOSE to isolate sound source. With answers to those questions, someone can suggest "Next Steps". George |
11-02-2022, 08:46 PM | #4 | |
Rep 8
