BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions 6wb retrofit update
      11-05-2022, 12:34 AM   #1
wzg30
Drives: 2018 BMW 530I
6wb retrofit update
Hey guys, so I retrofit a 6wb to my g30, then I put the old 6wa back to upgrade the system with dealer, after that, how do I upgrade the 6wb since it only have older cafd, do I change my car’s build day to get that newer cafd or how do it upgrade it? Thank you
      11-05-2022, 04:02 AM   #2
khile
Drives: G30 540i 2018
You will need Esys and you can change VO of car to remove 6WA and add 6Wb should be straight forward to do drop me a pm if you get stuck
      11-05-2022, 07:40 AM   #3
wzg30
I’m try to update that 6wb’s software, I understand vo coding, but since now my car’s I- lever is higher with “new” features, So I want to update the 6wb to get that same new feature
      12-11-2022, 04:30 AM   #4
elvir79
Drives: BMW 5
I recently did a cluster swap in my bmw g30 ... i had a analog cluster and changed it to 6wa. everything is working fine, except for navigation and mode button not showing media. is it possible to program this or do I have do upgrade my nav to proffesional?
      12-12-2022, 08:12 AM   #5
wzg30
Which car you have, might need change the build day
      12-12-2022, 03:05 PM   #6
elvir79
Drives: BMW 5
I have a 520d xdrive (2017)
      12-12-2022, 03:12 PM   #7
wzg30
That’s weird, but did you change your vo and code the hu and kombi ?
      12-17-2022, 06:26 AM   #8
elvir79
Drives: BMW 5
I had it done at a workshop and they said and need to upgrade the whole nav unit ... which is not cheap
      12-17-2022, 07:55 AM   #9
wzg30
No way, you talking about change to mgu ? Send pic so we can figure it out
      12-27-2022, 07:44 AM   #10
elvir79
Drives: BMW 5
as I understand ... I have a basic unit, but need a high version
5post
