11-07-2022, 04:02 AM | #1 |
Rep 33
how to improve ground clearance on M240i xdrive?
Do anyone know if there are a set of spacers to improve ground clearance? (regular m240i xdrive got 128mm, I need around 160mm).
I know many people will try to reduce g.c. actually, but I don't track the car, neither I drive aggressively, but I need more lightness (I deleted rear seats and also planning lightweight exhaust and ceramic brakes) and clearance in my vehicle. Also, do raised cars hold up well with time? I'm planning to keep this car (modified) for very long time. Thanks |
11-07-2022, 04:12 AM | #2 |
Rep 612
You mention you need to make the car lighter, but raising a car doesn’t make it lighter. What is the reason for wanting to raise it?
Raising the cars center of gravity will make handling worse, introduce more body sway, suspension will operate worse as it’s not designed for it as well. Also if you don’t track or drive aggressive why go through all the effort/trouble to make the car lighter? The car is already super heavy for what it is. Shaving off 100lbs isn’t going to make much difference. There are coil overs available for our car but I doubt they go higher than stock. |
11-07-2022, 01:58 PM | #3 | |
Rep 33
Weight reduction is for fuel economy purpose also. I like enjoying a 3.6 seconds car (on 0-60 mph) and not so bad fuel economy at the same time. But I really need to improve that ground clearance at least 1.5 inches. |
11-08-2022, 04:32 AM | #4 |
Rep 612
1.5 inches?!
Sorry to say but if you need that much then you bought the wrong car. To get that you will need to trade it in for something different that comes with that clearance stock. |
11-10-2022, 03:20 PM | #6 | |
Rep 706
And if you want a lighter vehicle, why buy a 4000 lb car? Ya want it lighter, remove the rear seats, remove the passenger seats, remove headliner, remove carpeting, sound sytem, speakers, replace glass with plexiglass/lexan etc....or buy a lighter vehicle...geesh...did ya buy this at gun point or what? wondering if this is just a troll or what? |
11-10-2022, 08:10 PM | #7 | |
Rep 33
Why porsche is introducing a 911 dakar trim? Why will be available with carbon roof and lightweight options? Different vehicles for different purposes make a vehicle polyhedric. Please, spare me your idiocracy membership. |
11-10-2022, 08:33 PM | #8 | |
Rep 706
Problem is the BMW 240 is not made for the purpose you wish so it seems a mismatch. But since that is what you do have: You need to re-engineer it. You would need to take it to a specialty shop and have the front suspension (struts etc) totally custom engineered and made specifically for you, and of course the rear suspension as well custom built. That would likely add weight, but specialty machining with lightweight alloys could reduce it but then mega costs result. Regardless cost would likely be considerable, but it would achieve what you want, anything is possible if you want to throw enough money at it. It would be something experimental for a specialty shop (if you can find one willing to do it), and the handling/roadworthyness might be in question. So seriously if you have the money...good luck...It would be unique. |
11-10-2022, 09:20 PM | #9 |
Rep 706
And then along with the suspension mods (which you will need for additional suspension travel etc with the roads you are talking about), you would want to throw say 21 or 22 inch rims all around with a taller aspect tire (50 or 60) as you will want that additional "tire cushion" to help keep the rims from being damaged with bad roads, plus its giving you ground clearance. That should easily get you an additional 1.5 inch of lift with more generous suspension travel to go with it. The taller wheel tire combo will likely need some underbody panels massaged/modified for clearance but that's no biggie. The bigger wheels and taller tires unfortunately will add weight so you are fighting that again, if you jump up in the price range considerably you may get the taller rims/tire combo close or lighter than stock?
11-11-2022, 03:33 AM | #10 | |
Rep 33
For my tires/wheels choice, I'll wait to see what lamborghini (huracan sterrato) and porsche (dakar trim) are cooking up for their vehicles. I think I'll have some inspiration from there. But for suspensions, I tried to figure out if kit spaccer (spaccer.com) can be a valid solution for ground clearance, without ruining the balance of vehicle too much. It should still be more firm than something like an X3 M40i, but still sounds like a temporary solution. I appreciate your post, and I think I'll follow your tips asking to some skilled shop. I'll update with posts once I start my works. Have a nice day |
11-12-2022, 06:57 AM | #12 |
Rep 433
Whilst this is a case of 'each to their own', I can't help thinking that any warranty claim is going to be hard to win!
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
11-15-2022, 02:40 PM | #13 |
Rep 1,559
Changing tires to 245/50r19 will give you 1.3" of additional ground clearance - that could be meaningful if you're driving around on dirt roads all the time.
All the weight reduction you've discussed is the same as throwing your cash into a bonfire. |
jpcoop364.00 |
11-15-2022, 09:33 PM | #14 |
Rep 140
Drives: '23 240ix, gone: '14 Audi RS5
Try reaching out to airlift, they may be able to come up with a solution for you.
https://www.airliftperformance.com/?...m_campaign=ALC |
