OFHG question Help.
11-07-2022, 09:23 AM | #1 |
Rep 11
OFHG question Help.
I have a 2010 BMW 335i E92 stage 2+ MHD, I started the car the other night and the low coolant light came on so I opened it and filled it but noticed it was weird looking on the inside after just dipping my finger in the tank I pulled it out covered in oil so I ordered the gasket kit, oil, coolant, and what not but my question is, would the OFHG cause the car to white smoke a little bit every now and then it’s not very frequent but under a little load, or I am gonna be replacing turbos soon? The turbos look fairly new from what I can see on the wastegate side and I don’t think it’s a head gasket because it doesn’t do it all the time. Thank all in advance
11-07-2022, 10:11 AM | #2 |
///Kenney
119
Rep 801
I’m sure you’ll defintely see some yes, don’t drive it in mean time until you get that OFHG/cooler gasket and o rings squared away ASAP.
Let previous oil drain for a good while and maybe consider doing an engine flush with liquid molys engine flush even though you would have to drain oil/filter that’s contaminated.. fill with a cheaper synthetic oil and filter and than add the engine flush. Let idle with 15-20 minutes than drain and re fill with youre choice of oil. |
11-07-2022, 10:12 AM | #3 |
///Kenney
119
Rep 801
Clean well or replace expansion tank and clean replace main coolant lines. I’d my vehicle is want make sure all coolant/oil contamainted items are cleaned or replaced
11-07-2022, 10:27 AM | #4 |
Rep 11
