11-12-2022, 04:35 PM | #1 |
Rep 54
Drives: 2020 BMW 330, 2023 BMW M4
Clicking / squeaking noise from stock suspension
I've had my G82 for 2 weeks now and I just noticed there's clicking and squeaking noise from the suspension. There's clicking and squeaking from the rear suspension when braking and accelerating and a ticking sound from the front suspension whenever I lock the steering wheel. My break in service is coming up soon and I'll bring it up to my SA then. Just wondering what the possible causes. Thoughts?
02-23-2023, 10:31 PM | #2 |
Rep 10
Hey, did you ever figure out what was going on with your suspension? I am noticing soft clicking/creaking in my front suspension when I go over bumps or accelerate at low speeds
Seems to happen when the nose is on a rebound/lift, when the springs are in tension |
05-12-2023, 09:54 AM | #4 |
Rep 277
Drives: '23 M3 Competition xDrive
Possible application here for the front clicking.
2023 Violet Blue/Fiona Red Full - M3 Competition xDrive
@violetblue_m3 |
Jon H396.50 |
05-16-2023, 02:00 PM | #5 |
You got my money?
3250
Rep 4,716
Drives: Ice Cream Truck
Call your service rep and ask him about this BWM SIB.
BMW has identified certain tie rods that are to blame for clicking sounds and will swap them out.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
07-07-2023, 04:43 PM | #6 |
Rep 620
Drives: Little of this, little of that
6800 miles and had the same complaint. It is this SB as worm stated. New tie rods ordered. 1 week turn around.
I don’t understand how this issue is the same issues other cars like the 230i or 330i have the same issue when the tie rods are not the same. “When turning the steering wheel while stationary or when driving on uneven roads; cracking, creaking, or knocking noises may be heard. See attached example sound videos V32 01 23 and V32 02 23. The breakaway torque in the thrust bearing of the tie rod is too high. Replace one or both tie rod assemblies”.
"It's not how fast you go, it's how you go fast"
07-11-2023, 10:43 AM | #7 | |
Rep 1,030
07-11-2023, 03:02 PM | #8 | |
You got my money?
3250
Rep 4,716
I am personal friends with my dealers shop foreman. He will do this service for me no problem. BUT... I must return my car to stock in order to get it done. That part sucks. So Ive lived with it. I assume I will go back to stock (lowered on HAS) to trade in the car before I go back to stock just to fix the clicking.
M4Tejas846.00 |
07-11-2023, 07:29 PM | #9 |
Rep 620
THAT is exactly the issue. Also a clunky sound when backing up. Cold weather esp.
07-11-2023, 11:26 PM | #10 |
Rep 1,030
07-12-2023, 01:40 AM | #11 | |
Rep 324
07-18-2023, 11:18 AM | #12 | |
Rep 620
Loosening the bolt might work but they are replacing the assembly on both sides because of the potential for damage that might have occurred. I am still in off-road mode with plans for springs. This came luckily before I did that. You know BMW would blame me for the issue. I do not have time for that shit.
07-18-2023, 05:38 PM | #13 |
Rep 361
07-19-2023, 01:35 PM | #14 |
Rep 1,030
07-20-2023, 06:37 AM | #15 | |
Rep 361
Nothing to worry about. |
chujk1985542.50 |
07-31-2023, 10:43 AM | #16 | |
Rep 1,030
07-31-2023, 03:45 PM | #17 |
Rep 620
Still waiting for parts to come in. In the mean time. click click click squeeeeeeeeeeeek
chujk1985542.50 |
08-06-2023, 08:28 AM | #18 |
Rep 511
2023 M4 here. Pretty bad I must say. Pick up the car from the dealer. Then, The very first speed bump already made clicking noise. I can feel it in the steering wheel, too. Now I’m on KW V3 coilover and the clicking is getting more frequent and louder. Made an appointment this week. We’ll see what he has to say. I’ll report back here
08-14-2023, 11:27 AM | #19 | |
Rep 1,030
08-23-2023, 06:52 AM | #20 |
Rep 54
Hey y'all. Experiencing similar symptoms. There is a clunking noise and I can feel in steering wheel over uneven terrain/sometimes smooth road. Turning/backing up & applying sharp brake pressure when going slow all bring out symptoms... just not consistently. I've gone to all my local dealers and they told me theres nothing wrong with the car, they did the same with my f80 steering issues. I'm going to dealer where I purchased the car that is 2hrs away. Is there anything I can do to bring out symptoms? Does anyone know if the SIB is still in effect? IF they bone me on this repair, i'm going to the aftermarket tierod route, has anyone used SPL tierods? Thanks.
08-24-2023, 07:50 AM | #21 |
Rep 6,840
The SIB is ALWAYS in effect as long as your car is in the designated VIN range. For this one I don't see it as being VIN specific unless there is a missing page.
Edit, here is the entire TSB: https://www.tsbsearch.com/BMW/SI-B32-01-23 Looks like the cutoff is MY 2023 although that could be because it was from March of this year before the '24's were out. |
M4Tejas846.00 |
08-24-2023, 08:00 PM | #22 |
Rep 620
My parts came in and I’m scheduled for install on 9/7. Will report back of it fixes the problem
