11-16-2022, 01:52 AM | #1 |
Rep 1
AFS Delete e60 - Winkpf expert mode
I have problem with Winkpf expert mode.
In comfort mode everythking work very well, but when i use expert mode i have erros like in screens. I must flash map without afs in dsc60, but i have errors. When i try flash dsc with maps dsca60 in conform mode everythinkg work Can you help me where is the problem? I do everythink like in instructions: https://www.car-auto-repair.com/winkfp-e...iguration/ I use K+dcan, everything is set up correctly, ista inpa etc ncsexpert works and executes all commands. What have i already done to remove afs: 1.I removed $217 from VO/FA and coded default KOMBI, SGM, SZL 2.Remove A/S Fuse #4–>40amp 3.I disconnected the afs module from car 4. I excluded errors from afs from the engine map The only thing left for me is to replace the map in the dsc module. I tried all numbers 6769705 6768908 6768648 every time I press expert mode, errors like in the attachment pop up. Of course I copied the files to develop supplementing Coap.ini with the map number and I have the same error all the time. I also changed the winkpf configuration in the options as in the manual. What is wrong? Thank you for every possible help |
