11-26-2022, 07:15 PM | #1 |
Rep 352
X7 Height Clearance with Roof Box
Hi,
I'm starting to look for a cross rack for the 22 X7. I have a old garage with 83' clearance. I'm wondering if any of you have any setup that can meet this clearance. Thank you, |
11-26-2022, 07:35 PM | #2 |
Rep 1,529
I was in the process of looking for one, and now that you just mentioned this, I wonder if that is a good idea given that when I travel to a nearby state we got to a lot of shopping-mall parkings and hotel parking, I am afraind that the total height would exceed the typical height limit for most hotel interior parking and shopping mall parkings…
Despite how big the X7 is, for a small family, 3-4 members, it barely holds enough luggage space.. and leaves nothing for new purchase and stuff on the way back home…. Which is why am thinking of the roof box now but I also don’t want it to prevent me from using interior parking areas. |
11-26-2022, 08:39 PM | #3 | |
Rep 1,657
As you have realized, there are parking garages and airports that will be causing anxiety, can’t use a car wash, causes wind noise, hurts fuel economy. That’s why getting a cargo box and roof rail system that’s easy-on/easy-off is being recommended by so many. |
javacodeguy1.50 |
11-26-2022, 08:48 PM | #4 | |
Rep 1,657
I’ve got an old garage too. When we put up the cargo box we park the car outside. And in doing so we can get the biggest box possible with no limitations. |
11-26-2022, 08:50 PM | #5 | ||
Rep 352
11-26-2022, 11:23 PM | #6 | |
Rep 76
past: 2008 x3
past: 2014 mini cooper jcw past: 2016 435xi coupe on order: 2023 x7 m60i |
11-28-2022, 08:14 AM | #7 | |
Rep 1,657
The OEM crossbars require no tools, just turn the knob a few times, when removing or adding them it takes about 15 seconds per corner or 1 minute in total. The cargo box is a different story as it takes 2 people to put it up on the roof and about 30 seconds per corner to set it down straight, tighten the knobs, double-check that it's centered, etc. or 5 minutes in total. So that's why one needs to look at this as situational. When you need it, you put it up. When it's in the way, you take it down. It only takes 5-6 minutes each time depending on whether or not you want to remove the crossbars as well. |
11-28-2022, 08:20 AM | #8 |
Rep 1,657
I don't think you're going to find a set of crossbars and a cargo box that combined is less than 10" tall. Assuming you use a 2 piece ski rack atop the car currently, I think that's the best you're going to get. That's what we use in our old garage. Just clears the door and the automatic garage door motor by a few inches.
11-28-2022, 08:26 AM | #9 | |
Rep 352
11-28-2022, 01:26 PM | #10 |
Rep 1,088
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
At 83" you won't prolly make anything besides the bare cross bars. My wife is supposed to check any hotels she books for trips where we use the box now. In Vegas at the Cosmo it fit in one entrance but not the other, but only the first level as the height reduced for sub levels. At DL the hotel we stayed it wouldn't fit, luckily they had a surface lot but no one liked to park in the garage so finding a spot was a struggle.
Worst case scenario is always take the box off and store in the room.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
11-28-2022, 03:12 PM | #11 | |
Rep 352
One of my friend has a Thule Alpine Vector available to sell. I'm debating to get it from him for $800 plus extra couple hundred for the bars or just Ski racks. But the Thule looks so damn good. |
11-29-2022, 05:52 AM | #12 |
Rep 57
I have a garage with 2205 mm (approx 87 inches) of clearance, and the only option that I could find that would fit was Thule aero bars + Thule alpine box. With this setup, there is additional 6mm (1/4 inch) of room.
As others have mentioned, I do not believe 83 inches is possible. Personally, if a roof box is not possible then I would try to fit the skis inside the car. Last edited by k23435; 11-29-2022 at 08:30 AM.. |
unfoundnemo1923.00 |
11-29-2022, 12:05 PM | #13 | |
Rep 352
11-29-2022, 04:26 PM | #14 | |
Rep 991
Also for ski's we plan to just throw them in a ski bag and put inside the vehicle. The X7 is so tall it makes it difficult to put the skis up and take them down from the top. |
11-29-2022, 10:15 PM | #15 | |
Rep 1,657
Ah, but that's where the Thule Snowpack 6 and the BMW running boards are your friend. Not hard at all with this setup, even in ski boots. |
11-29-2022, 10:20 PM | #16 | |
Rep 991
Lengthwise skis should fit in between the captains chairs or drop the center part of the bench seat and slide them in there. |
11-30-2022, 09:20 AM | #17 | |
Rep 1,657
I stand on the running boards, each family member lines up, and they hand me their skis. Takes less than 60 seconds to get all 5-6 pairs of skis up there, close the bar, turn the lock, and drive off. Sometimes we stay for a long weekend at a condo that isn't ski-in so leaving the skis on the roof for the next day is a blessing and it leaves the passenger compartment clear if we decide to drive to a restaurant for dinner. |
11-30-2022, 12:30 PM | #18 |
Rep 352
He still has it. I just asked him and PM you.
11-30-2022, 12:32 PM | #19 | |
Rep 352
11-30-2022, 01:07 PM | #20 | |
Rep 1,657
Also I'd imagine that whichever skis are in the bottom of the box and farthest away from where you're standing would be hard to get out as you'd have to reach far across the car and down in the box. With 6 pairs of skis in there it sounds like a muscle pull waiting to happen. Check out the Thule SnowPack L which holds 6 pairs of skis. It's what I use. |
11-30-2022, 01:14 PM | #21 | |
Rep 57
https://g07.bimmerpost.com/forums/sh...8&postcount=23 |
11-30-2022, 04:24 PM | #22 | |
Rep 352
Thank you for sharing! |
