BMW X5
      11-30-2022, 06:53 PM   #1
Bavar-ian
Bavar-ian's Avatar
Singapore
178
Drives: X5 G05
Heat exchanger coolant change
Planning to flush out the factory coolant for the water-air cooler as ambient temps at where i am at on avg 35deg C.
Is there a bung to drain them out and fill or jz a matter of pulling out the top hoses to drain and fill via expansion tank?
Thank you.
      12-02-2022, 01:05 PM   #2
eelnoraa
Drives: G05 X5
How many miles? Is there any reason to flush?
      12-02-2022, 04:47 PM   #3
Bavar-ian
Bavar-ian's Avatar
Singapore
178
Drives: X5 G05
Replacing it with VPracing cooldown in a bid to try and attain lower IATs, still new to be looking at an aftermarket core which will void engine warranty.
About 35deg c on avg here at where i am.
eelnoraa2058.00
      12-02-2022, 06:37 PM   #4
gfeiner97
Drives: X540i
This should help. . See attached. It's for a 40i sDrive. The coolant system is divided into a "high temp circuit" and a "low temp circuit".
      12-05-2022, 11:35 PM   #5
Bavar-ian
Bavar-ian's Avatar
Singapore
178
Drives: X5 G05
No attachment!
      12-07-2022, 06:42 PM   #6
gfeiner97
Drives: X540i
Originally Posted by Bavar-ian View Post
No attachment!
I don't know why you can't see them. they are there.
Bavar-ian177.50
      12-08-2022, 12:43 PM   #7
Tejas1836
Tejas1836's Avatar
1002
Drives: 2023 X5MC Workmaster 75
No attachment!
Check your downloads folder on your computer
xbimmers
