12-05-2022, 09:19 PM | #1 |
Rep 51
255/55 R20 on original 8.5" wide rim
I plan switching the original AS 235/60 R20 on my iX 50 with 255/55 R20 winter tires (Nokian Hak. R5 SUV) using the original 8.5" wide rims. Any reason to avoid this plan?
12-06-2022, 06:35 AM | #2 |
Rep 608
Drives: F15 X5 50i, G30 M550i, iX 50i
No, you're fine with that. The ET25 offset on the 20" rims will fit up to 285/50R20 tires without rubbing. You can go 255/55R20, 265/50R20, 275/50R20, 285/50R20. I'm running 275/55R20 (tall 2.8%) for my winter set and there's no issues with rubbing.
12-06-2022, 07:51 AM | #3 |
Rep 1,993
It sounded to me like the concern was more about how wide the tire is for the rim width of 8.5". Most charts I find by googling say that for a 8.5" rim, 255 is the widest they recommend so the OP should be good, but I'd always defer to a tire/wheel shop who knows better than me. Not sure what the effect of going wider than that has.
12-06-2022, 03:37 PM | #4 | |
Rep 608
I generally don't trust tire shops, but if you want the official answer you should defer to the exact manufacturer's website (in this case Nokian) and they should have the specs. I checked Nokian and it's hard to find on there but I just went off the Toyo site for the tire I got and it gave those rim specs. In any case, you're fine. Going wider than 255 on a 8.5" rim will have a small effect of "bubbling" where the tire protrudes out from the wheel slightly. I actually prefer running wider tires on narrow wheels, giving the wheels more protection from…my wife's parallel parking skills. |
12-13-2022, 10:27 PM | #6 |
Rep 60
It's been a while since I bought dedicated snow tires but its been my experience that wider / lower profile tires do NOT work better in winter conditions... Just my thoughts.
