E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Just got my Procede Rev.II!!
Reply
      01-02-2009, 02:39 PM   #1
prich2004
prich2004's Avatar
Drives: E90 335i
2008 E90 335i  [0.00]
Update 1: Just got my Procede Rev.II!!
I just got my Procede Rev.II delivered today! I also have a DCI on order too. Once that gets here in about a week, I'm going to have a shop here in Houston install it. The documentation states that I have Stg. 1 DD maps installed. I'm wondering if I should wait for the Non DD maps to be posted before I get it installed since I don't want to go in and muck around after I am done installing it. I plan on getting my car on a dyno before I install everything to get a baseline performance measurement (Jan. 10). I'll post the before and after.
Edit: 1.10.2009
Ok, here are my dyno results for my stock AT car. 65 F ambient temp. The dyno figures are different as you can tell. The Dyno was a quick run from 4000RPM. The reason it was done this way is because the car kept downshifting to stay in the powerband. In order to go around that, we did run from 4k RPM. How can you properly dyno this car if it has AT and keeps wanting to downshift?? Please post your ideas/best practices. If we can get a better method, FWD Performance will re-dyno the car for free. I think the dyno was performed on a Dynocomp machine which has similar results as a Mustang dyno (on the low side).
E90 335i | Metallic Graphite | AT Step | Sport | Premium | Satellite | iPod | Ceramic Tint | PROcede V4 | BMS DCI
      01-02-2009, 02:56 PM   #2
M3to335
Whats that smell?
M3to335's Avatar
Drives: Bimmers, duh
Just install it yourself. It couldnt possibly be any easier
      01-02-2009, 03:02 PM   #3
prich2004
prich2004's Avatar
Drives: E90 335i
Ya, never done anything like it before. I rather not live with the guilt if I mess up!
      01-02-2009, 03:02 PM   #4
Ryan@Motorwerks
Ryan@Motorwerks's Avatar
48
Drives: X3M
What shop are you going to?
      01-02-2009, 03:03 PM   #5
prich2004
prich2004's Avatar
Drives: E90 335i
Yours
I talked to Sunil last month and he said that he could take care of everything for me. I really liked the shop and the fact that you all have worked on modding 335i's. The shop seems to have a good rep among the BMW community in Houston.
      01-02-2009, 03:11 PM   #6
David 12
David 12's Avatar
130
Drives: 2019 BMW X5 50i BSM, M Sport
Let us know how you like your new Procede as well as differences between dd and ndd.
      01-02-2009, 03:11 PM   #7
SfValley335i
Afghanistan
165
Drives: Current:135i Sold:335i sedan
Install it NOW and then run a USB cable into the glove box so you can do updates without removing parts....
      01-02-2009, 03:12 PM   #8
PaulBailey@ltbmw
PaulBailey@ltbmw's Avatar
Italy
665
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Enjoy that man!
Its makes the car even more fun the drive. . . if you can believe that
      01-02-2009, 03:14 PM   #9
prich2004
prich2004's Avatar
Drives: E90 335i
I was totally thinking about running the serial to usb through my glovebox...thanks for the reminder. I'll make sure I bring one to the shop.
      01-02-2009, 03:37 PM   #10
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
Awesome! I am sure you will enjoy it!
      01-02-2009, 09:23 PM   #11
NM_BMW
Vishnu Powered
NM_BMW's Avatar
Drives: 335xi, S1000RR
+1 Anyone who has a procede should do this without even thinking about it. It is just as easy to install as the PNP procede.
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3
      01-03-2009, 03:27 PM   #12
prich2004
prich2004's Avatar
Drives: E90 335i
I just bought the serial-usb cable. Does anyone know if valet mode comes preloaded or do you have to enable it yourself?
      01-03-2009, 03:34 PM   #13
NM_BMW
Vishnu Powered
NM_BMW's Avatar
Not sure, but since you have the serial-usb adapter just open up the procede software and find out if it is enabled. If not, just enable it.
      01-03-2009, 10:22 PM   #14
e55lover
Drives: 335 e90
how much did you pay for it?
      01-03-2009, 10:33 PM   #15
Ryan@Motorwerks
48
Drives: X3M
Well by the time you come by, the C230 with the S55 AMG engine should be back from the paint shop. Beast!!
      01-03-2009, 10:42 PM   #16
prich2004
prich2004's Avatar
Drives: E90 335i
$945 for the Procede Rev.II Race and $99 for the BMS DCI.
I'll be at MW Jan. 12 after I do the dyno. I'll get the car on the dyno again after I get everything installed. Can't wait to take a look at that C230 with the S55 AMG engine...that's crazy.
      01-10-2009, 03:29 PM   #17
prich2004
prich2004's Avatar
Drives: E90 335i
Updated post with stock dyno numbers. I think I need recommendations on how to improve the dyno results since I was only able to make pulls from 4K RPM. Since the car is AT, it kept downshifting to have max power in the powerband.
      01-10-2009, 03:32 PM   #18
ljg335i
Drives: E90 328xi LCI
Use steptronic and don't click the "button" at the end of the gas pedal travel. It will hold the gear until shifting at redline
Current:
2011 328xi BSM/Black
Past:
2002 325i/2007 335i/2004.5 A41.8T
      01-10-2009, 03:34 PM   #19
prich2004
prich2004's Avatar
Drives: E90 335i
I think some runs were done only in DS mode too....I dont get it.
      01-10-2009, 03:54 PM   #20
alextremo
Drives: F10 550i
When you shift manually in DS mode the car won't change gears until something bad is about to happen. It will hold until redline. Key is shifting manually.
      01-10-2009, 04:05 PM   #21
prich2004
prich2004's Avatar
Drives: E90 335i
If you shift manually while in DS mode, you are in "manual" mode (M). If I am in M5, and I floor it, the car will downshift to M3 or M4 by itself...
      01-10-2009, 04:11 PM   #22
Boost Gomez
Boost Gomez's Avatar
Drives: C63 AMG
2007 BMW 335i  [0.00]
Do not floor it past the kickdown button..
Reply
Tags
dci, dual cone intake, procede, rev.ii, tune
e90post
