12-09-2022, 02:25 PM | #1 |
Rep 32
Drives: BMW 220i 2022 COUPE
BMW 220i COUPE FILLER CAP
Hi Guys, new here I have a 2022 220i coupe in brooklyn grey metallic. Spotted an issue with my car where the filler flap is protruding, took to my local bmw centre and they said it's normal for this model and within tolerance etc.
Wanted to just reach out to owners of the same model here and see if you have the same issue or amount of protrusion. I've attached an image to compare look at the bottom of the filler flap. Thanks Christopher |
12-09-2022, 10:02 PM | #2 |
Rep 177
Definitely not normal
Door should be flush with the body Does the door lock when you push it in? |
BMW2OWNER202220.50 OnlyGerman363.50 |
12-11-2022, 03:36 AM | #3 |
Rep 32
Thanks for the reply. Yes it locks without issue, top is flush bottom is not. Was told this is normal as compared with other cars of the same model on-site.
12-11-2022, 04:18 PM | #4 |
Rep 77
They are bulls hitting you mines perfect, yours is not, play hell at the dealer
BMW2OWNER202220.50 |
12-12-2022, 12:40 PM | #5 |
Rep 32
Thanks for the info, if not much trouble could you send a pic when next out and about so atleast I can show them. Cheers Chris
12-14-2022, 04:32 AM | #7 |
Rep 433
Total rubbish, mine's perfectly flush with the wing
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
12-14-2022, 02:29 PM | #8 |
Rep 32
Thanks this is very useful for me. I’ve been back onto them and they are going to see what they can do!
12-14-2022, 03:34 PM | #9 |
Rep 748
Another datapoint if needed. Mine is perfectly flush as well.
12-16-2022, 11:04 AM | #10 |
Rep 32
Thanks for this very helpful. They are having it back in the new year for a few days to investigate further and try and rectify. I used these posts to help with the images so thanks again.
I did notice tonight when putting fuel in, as slight gap between the plastic and the flap, was thinking it may just not have been “snapped” in correctly. I’ve attached an image.. Cheers again, Chris |
12-16-2022, 11:07 AM | #11 |
Rep 32
Image here…. I think lol
12-26-2022, 04:25 PM | #12 |
Rep 706
That's likely the source of your problem.
01-04-2023, 08:27 PM | #13 |
Rep 1,261
Go to another dealer
01-16-2023, 02:23 AM | #14 |
Rep 504
Any update on this? Mine is isn’t quite flush along the bottom edge either. I took the painted fuel filler door off. Just stick a flathead screwdriver into the notch where the black plastic support frame is and slide the fuel filler door out. All the tabs (6 total) are locking in securely. The issue seems to be the shape of the plastic fuel filler door itself.
2017 Chevrolet Corvette
2023 BMW M240i xDrive |
01-26-2023, 01:15 AM | #15 |
Rep 32
Hi Coconut, yeah it’s annoying. No update yet it’s going to the dealership on Monday, was postponed due to bad weather. I’ll let you know.
I do have another issue though unrelated, condensation on the inside of the drivers side headlamp… another annoying problem! |
Coconut768.50 |
01-31-2023, 01:39 PM | #16 |
Rep 32
Hi coconut, they have taken the filler door off, and housing out and refitted, and it seems to look ok by the images they sent, but I’ll see in the flesh tomorrow when I pick it up.
Just to add they said adjustment of the black housing arm was causing most of the issue, the flap itself was in shape and ok. Headlamp being changed for a new one, this is on lead time so not done yet. |
