NA
12-12-2022, 07:02 AM | #2 | |
Rep 3,732
The transmission will adjust on it's own if it needs to....that's the whole point of the adaptations. Back when I did a full service on my transmission and also replaced all the shift solenoids....I didn't reset the adaptations. And guess what, after a few hundred miles of driving, the adaptations changed, because the transmission adjusted them. There is a reason why XHP, ZF, and people that special in the ZF transmissions tell you not to reset them. Resetting everything to factory new default settings....without having factory new parts, is a horrible idea. Not to mention the extremely long and tedious relearn procedure that you need to go through in order to get the transmission to shirt good again. Never reset the adaptations.....
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
Eriksson770030.00 |
