12-17-2022, 01:16 PM | #1 |
Rep 313
Wired Audio MY23
I can’t seem to get my phone to show up as a mobile device for music when only connected by lighting to usb-c cable in the center console. It always worked that way on idrive7 vehicles. Am I missing something or did they remove wired audio? I can’t believe with this B&W system the only way to listen to high quality music is over wireless CarPlay which is limited to 16bit.
2023 BMW X7 LCI M60 (On Order) 2020 BMW X7 xdrive40i M Sport Phytonic Blue 2019 BMW X5 xdrive40i Mineral White |
12-17-2022, 01:19 PM | #2 |
Rep 1,529
What happens if you try to do the same without AppleCarplay? I.e. regular idrive media/Audio app?
I hardly believe they’d remove the wired connection method. That Will immediately the extreme benefit the B&W or even HK has over other systems. |
12-18-2022, 08:08 AM | #3 |
Rep 313
I unpaired the phone and when I plug it in it doesn’t show up.
12-18-2022, 02:42 PM | #4 |
Rep 1,529
I think AppleCarplay in BMWs starting from ID7 has always been through wireless connection only. I understand you said it used to work just fine when wired in pre-LCI, but I wonder if data was still shared via a wireless connection regardless. Note: am only referring to audio via CarPlay; but am not sure about the iDrive media (which in my opinion, should still be an option for wired connection just like in the pre-LCI). I doubt they removed this capability. Wired connectivity is a must for B&W to work up to it's max quality threshold.
12-18-2022, 03:08 PM | #5 |
Rep 294
On the 2023 X7 for wired audio you must now use the USB jack next to the front Cupholder which is 1.5A. The USB-C jack in the center console is for charging only and is 3A. Same for my 2023 M5 with iDrive 7 as well.
2023 M5 Comp Skyscraper Grey,Executive Pack, Drivers Assistance, B&W, 789's. |
12-18-2022, 06:56 PM | #6 |
Rep 27
Does the wired connection also allow for streaming or only local media?
12-19-2022, 08:34 PM | #7 |
Rep 313
[QUOTE=SSM5;29652327]On the 2023 X7 for wired audio you must now use the USB jack next to the front Cupholder which is 1.5A. The USB-C jack in the center console is for charging only and is 3A. Same for my 2023 M5 with iDrive 7 as well.
Wow, that sucks, there is no where neat to put the phone in that area and A a becoming obsolete. I’ll have to test it out.
