12-18-2022, 10:17 PM | #1 |
![]() ![]() 307
Rep 187
Drives: 2023 M8 Competion Coupe
Coming from Mercedes, I’m use to slightly pushing the break pedal a bit harder at a stop light to initiate break hold. Works great.
With my new M8, there’s a button that does the similar thing as my past Benz. It works the same, but the only downside from what I’ve seen is that it constantly stays on and is annoying when pulling into a car space or my garage. I prefer the engine to do the work versus tapping my gas peddle to initiate the car to move forward in my garage, especially with 617 HP. No I’m not bashing BMW, I was just used to soemthing on the Benz and if it doesn’t function the same, oh well, no sweat. Can someone confirm if break hold can be activated by pressing the break pedal slightly harder like on a Mercedes or only in the way that I’ve been using it? |
12-19-2022, 04:24 AM | #3 |
![]() ![]() ![]() 6566
Rep 15,857
As long as users don't confuse Brake-Hold with the "Drive-off Assistant" you are describing above.
To the OP, you can switch Brake-Hold off and use the (timed out) Drive-off Assistant for situations where Brake-Hold is less suited. |
12-19-2022, 04:29 AM | #4 |
Rep 15,857
12-19-2022, 10:50 AM | #5 | |
![]() ![]() 307
Rep 187
Yeah that’s what I thought. I definitely miss that feature but oh well, all good! |
12-19-2022, 12:50 PM | #6 |
![]() 1225
Rep 1,023
This is what I am describing:
"Principle The drive-off assistant supports driving off on uphill grades. Driving off 1. Hold the vehicle in place with the foot brake. 2. Release the foot brake and drive off without delay. After the foot brake is released, the vehicle is held in place for approx. 2 seconds. Depending on the vehicle loading, the vehicle may roll back slightly." |
12-19-2022, 12:53 PM | #7 |
![]() ![]() 307
Rep 187
https://m.youtube.com/watch?v=8LU3qJ4ZGJI
The key difference here is the break hold is only activated by pushing down the brake pedal a little bit more than usual. It’s not constantly running like when you have the button turned on like BMW does it. |
12-19-2022, 12:54 PM | #8 |
![]() 2231
Rep 3,113
Drives: 2020 BMW 530xe
Another former Mercedes driver here.
The Mercedes way of activation just makes much more sense. There isn’t an “on/off” setting for it as it isn’t needed. You activate it by pressing the brake peddle harder, as you mentioned, when stopping. BMW doesn’t do it this way. For BMW you first have to activate “Hold” under the shifter and it will be on until you turn it off again and is remembered between drive sessions. You then come to a stop and it will automatically activate the function. Pressing harder won’t influence its activation. I also don’t believe you can deactivate it with a tap of the brake pedal like Mercedes either. You have to tap the gas. I used to tap the brake on the Benz to prevent that jerky start feeling as the car removes the brakes and starts going from the gas pedal that can startle your passengers. At least BMW “fixed” the turn signal stalk on the G30 compared to older models. That would have taken me a longer time to adjust to I feel. |
M8CompSoCal307.00 Sal@AUTOcouture752.00 |
12-19-2022, 12:54 PM | #9 | |
![]() ![]() 307
Rep 187
12-19-2022, 12:56 PM | #10 | |
![]() ![]() 307
Rep 187
LogicalApex2231.00 |
12-19-2022, 01:09 PM | #11 |
![]() 58
Rep 89
The MB way makes more sense. Though when I test drove the GLE I couldn't for the life of me get it to work. Either I pressed too light or too hard and never got it to engage. The salesman explained it to me and I attempted multiple times but to no avail. I'm sure once you get familiar with where the engagement point is then it would be a lot more convenient. I always have to turn off brake hold when parking in the garage for my cars.
12-19-2022, 01:21 PM | #12 | |
![]() ![]() 307
Rep 187
12-20-2022, 03:32 AM | #13 |
![]() 74
Rep 70
This is exactly why I don’t use auto brake hold in my car. What I find weird though is that some other BMWs I’ve driven function the same your Benz does including both pre-LCI and LCI G20 3 series. I wonder if it’s something that can be coded.
M8CompSoCal307.00 |
12-20-2022, 06:05 AM | #14 | |
Rep 15,857
Both the Drive-off Assistant and Auto-Hold use the service brakes. |
12-20-2022, 09:20 AM | #15 |
![]() ![]() 307
Rep 187
If you find anything about this send me a DM. Thanks.
12-20-2022, 03:02 PM | #16 | |
![]() 2231
Rep 3,113
12-20-2022, 08:07 PM | #17 | |
![]() 74
Rep 70
HighlandPete6566.00 |
12-21-2022, 12:26 AM | #18 | |
![]() ![]() 307
Rep 187
Same here. |
12-21-2022, 12:42 PM | #19 | |
![]() ![]() 3009
Rep 4,210
12-21-2022, 02:25 PM | #20 |
Rep 15,857
I suggest that is all in the pressure tolerances and brake feel of different models.
12-22-2022, 11:46 AM | #21 |
Leave the gun. Take the Canoli.
10526
Rep 8,522
My previous M4 was my first car to have this feature and overall I love it. I've never driven a MB to see how it is in comparison, but sounds like an interesting difference. Its interesting to see the little things that car manufacturers do similar but differently. I was looking at some Aston Martin's and their center screen is a dinky 8" compared to the 12" screen in my X3 and M8.
Current: 2025 X5 M60
Retired: 2023 M8 ||| 2023 X3 M40 ||| 2021 M4 ||| 2018 M4 ||| 2017 M4 ||| 2014 435 ||| 2009 335 ||| 2007 335 |
M8CompSoCal307.00 |
12-22-2022, 12:31 PM | #22 | |
![]() ![]() 307
Rep 187
