Adaptive headlights question
01-10-2023, 08:14 PM | #2 |
Rep 4,325
In the US, there was only adaptive/xenon and halogen.
Other countries had xenon without adaptive. Run your vin on mdecoder.com to see what your car had from the factory. |
01-10-2023, 08:32 PM | #3 |
Rep 446
Drives: '11 E93 M3 6MT, '08 E92 335Xi
just as an FYI:
the original window sticker for my 2008 E92 335xi lists Xenon Adaptive Headlights under Standard Features But my VIN decode lists Adaptive Headlights as Option S524A and Xenon Light as Option S522A
Pete
01-11-2023, 11:29 AM | #7 |
Rep 4,325
On e90/1 pre lci and lci they can turn side to side and up and down.
On all lci, I’ve seen them turn side to side. On some pre lci, I’ve seen coding required for side to side movement. I have not noticed any side to side movement on e92/3. Lci e90/1 and e92/3 have the inner cornering lights that turn on when turn signals are turn on, when turning and when in reverse. Post a picture of your headlights OP. |
k9043.00 |
01-11-2023, 11:33 AM | #8 | |
German Car Caregiver
32
Rep 28
Drives: 2014 BMW 535i M-Sport
01-11-2023, 05:41 PM | #12 |
Rep 815
If the OP has/had xenons, wouldn't he have the leveling sensor (up/down) on the rear subframe and the directional sensor (left/right) on the driver's side wheel? I can imagine that someone might have changed the bulbs, but probably didn't pull off the sensors.
01-11-2023, 08:04 PM | #13 |
Rep 4,325
^^ That would be for adaptive w/ xenon lights.
Xenons w/o adaptive don’t use any of that. OP does mention previous owner installed LED low beams. There is D1S LED bulbs but they are still fairly new and not known about by most.(Led bulbs in place of xenon bulbs) Probably has halogen lights. Won’t know until he runs the vin or posts a picture of them. |
01-11-2023, 08:16 PM | #14 |
Rep 1,508
Might have just flashed out the adaptive movement to get rid of the dash warning.
01-12-2023, 12:11 PM | #15 | |
Rep 642
Also coded did the same for a shop who was repairing a car for a customer who had issues with their lights that just wanted the car to not have the error. If OP's car is a white 335is in central FL you need to code them back in lol. |
