01-16-2023, 02:02 AM | #1 |
Rep 221
Brake Pad change help
Hey guys so i did a brake pad change and the left side was so issue but on the right side i accidentally disengaged the bimmerlink brake service while my caliper was off the rotor and it fully pushed the piston out to the point where some oil leaked out we managed to push it back in place with no more oil leaking to our knowledge but when i brake now the car takes 1-2 seconds to fully start braking and the first push of the brake feels very weak until i get lower and it stiffens, any help would be appreciated as i want to make sure i did not mess up my car with the piston fully pushing out and it leaking a bit. Also i think we pushing the piston in while not have brake service engaged would anything be damaged.
01-16-2023, 02:37 PM | #2 |
Rep 553
Drives: 2022 G83 M4
Ouch sorry to hear that. What you're describing sounds like you have some air in the line which should be resolved by the dealer with a brake fluid bleed. Not sure if you did any internal damage by retracting the caliper piston without service mode especially since we now have the electric parking brake. I'd personally start with the brake bleed and see if it resolves the issue.
2022 G83 M4 Convertible Isle of Man Green on Tartufo Instagram:kermit_g83
2020 GLE 450 Emerald Green on Macchiato Beige - wife and baby mobile 2016 M3 TB on SS - gone but not forgotten |
01-16-2023, 06:36 PM | #3 | |
Rep 221
01-19-2023, 03:12 PM | #4 |
Rep 704
Drives: 2023 BMW M4 Competition
Yes to air in the system.
You can bleed the brakes yourself. It's a really simple process that only takes two people. No need to take it to a shop. One to pump/push the pedal One to open the bleeder on the caliper Youtube the process if you don't know how. |
01-19-2023, 03:56 PM | #5 | |
1967
Rep 1,927
Drives: E92 M3
When you try it, the brake pedal will shake and you'll end up bring in more air to the system. That's what the dealer techs did at my last track day when I asked them to refresh the fluid and they ended up having to get more tools out to fix it. You need to do a pressure bleed and then activate the ABS to get more air bubbles out. An independent shop should be able to take care of it, no need to go to a dealer.
FISH225416.50 |
01-19-2023, 04:48 PM | #6 | |
Rep 704
Are you sure that procedure is not just if there is air in the ABS? If the battery is disconnected the system becomes a manual brake system and should be able to blead it like a normal car. A pressure bleed is pretty simple too. But the battery needs to be disconnected. And don't yell at me... |
01-19-2023, 10:22 PM | #7 | |
Rep 292
https://g80.bimmerpost.com/forums/showthread.php?t=1921666 |
01-20-2023, 12:18 PM | #8 | |
Rep 704
The instructions posted show if you have a pressure bleeder you can still do it yourself. If you don't have one of these and track your car they are cheap. |
FISH225416.50 |
