01-19-2023, 03:47 AM | #1 |
Rep 84
Can I return my OBD2 adapter and still flash to stock with a different adapter?
I have a F30 340i and I have the THOR wifi adapter and I used that to flash XHP on my transmission. They listed that the adapter is compatible with MHD ECU tune also, but that is not the case. So, I bought an MHD adapter for my ECU tune that I'm planning to install. XHP also works with MHD so, I don't need the THOR adapter anymore. Therefore, I am planning to return the THOR adapter since they mislead me on the MHD tune compatibility.
My question is that will I be able to flash my transmission back to stock with the MHD OBD2 adapter or will I have to keep my THOR OBD2 adapter since my vehicle info is on the THOR adapter? |
01-19-2023, 06:13 AM | #2 |
Rep 3,909
The adaptor has no memory - nothing is "on" it - it is just an interface device!
And that answers your question - you can(re)flash with any compatible adaptor, you can mix and match or use a different one every time - it does not matter, as long as there is compatibility.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
01-19-2023, 08:06 AM | #3 |
Rep 5,409
Drives: 2015 BMW 335i x-Drive Auto
The adapter just supplies a standard connection. Doesn’t matter which adapter you use. The application doesn’t know the difference.
